8-Pin USB UART
2 posts / 0 new
Might be an interesting chip for fellow freaks, an 8-pin USB 1.1 USB to Serial Bridge...
http://prolificusa.com/portfolio...
This one is cute (also full-speed, no quartz or LDO needed):
http://www.microchip.com/wwwprod...
In PDIP-14, SOIC-14 and other.
No RSTDISBL, no fun!
