creating header files
15 posts / 0 new
This is the code that i wrote for Adc with two functions Adc_init() and Adc_read().
This file is to be named 'adc.c'.I would like to know how i can create a header file 'adc.h' and for that how should i define these two functions inside it.
#include
void Adc_init(void)
	ADMUX|=(1<<REFS0)|(1<<MUX0)|(1<<ADLAR);//adc1 seleceted with avcc as reference
	ADCSRA|=(1<<ADEN)|(1<<ADSC)|(1<<ADPS2);//prescale by 16
int Adc_read()
{int_8 adc_val;
	adc_val=ADCH;
   return(adc_val);
the more is see,less i know
void Adc_init();
int Adc_read();
Sid
Life... is a state of mind
so it will be like
#if
void Adc_init();
int Adc_read();
#endif
My doubt is that what kind of 'type cast' must be given to read adc values.As it will be sensitive to the cast given in c language.
Type casts are only required when it wont be clear to the compiler how to make a type conversion.
However C already has implicit rules (integer promotion) that will automatically handle such conversion.
For example, as written above your read function reads ADCH which is uint8_t but returns int. We could question why the function itself doesn't also return uint8_t (nothing is really added by making it int, it will still be 0..255) but anyway the unsigned char (uint8_t) will automatically be promoted to int without requiring a type cast.
arun_nr wrote:
so it will be like
#if
void Adc_init();
int Adc_read();
#endif
What exactly do you mean by the empty #if?
Normally it is a good idea to include a condition to protect the header from multiple inclusion.
Something like:
#ifndef _ADC_H__INCLUDED_
  #define _ADC_H__INCLUDED_
  void Adc_init();
  int Adc_read();
#endif
Alex
"For every effect there is a root cause. Find and address the root cause rather than try to fix the effect, as there is no end to the latter."
Author Unknown
In the cse at hand, static inline fucntions in the header file are probably the way to go.
int Adc_read()
{int_8 adc_val;
   adc_val=ADCH;
   return(adc_val);
No need for the intermediate variable here. Simply use:
int Adc_read()
   return ADCH;
Steve A.
Koshchi wrote:
int Adc_read()
{int_8 adc_val;
   adc_val=ADCH;
   return(adc_val);
int Adc_read()
   return ADCH;
I would expect that 'int_8' is a signed type, and then there is a difference. His version does a sign extension, yours not. If the sign extension was intended, then the direct return must look like this:
return (int8_t)ADCH;
Stefan Ernst
Hi
i am having a similar problem by using files at the same time.
I am using main.c adc.c and adc.h
i am not able to compile this as it shows
compiler avr-gcc
the file has been added to Pwm.rar.I trust including the header file is the problem.
undefined reference to Adc_init() and Adc_read
[u]
To be strict:
void Adc_init (void);
int Adc_read (void);
No, the problem is that you have not added adc.c to makefile. Add it here:
SRC = $(TARGET).c adc.c
Steve A.
well i have a different problem
in the main.c if i gave simply
  void Adc_init();
        int Adc_read();
	void Adc1_init();
        int Adc_read();
it wont give an error
but when i give variable to the read function
like v=int Adc_read();
i=int Adc_read();
it shows compile error.The screenshot of this is available here in the attachment.
  void Adc_init();
        int Adc_read();
	void Adc1_init();
        int Adc_read();
i=int Adc_read();
That's not valid syntax. This is a function prototype or declaration:
int Adc_read();
It tells the compiler what types the inputs (parameters) and output (return) of the function are. To call the function you need to take off the return type and replace the parameter types with arguments; in this case there are no parameters:
Adc_read();
You can save the return value to a variable like this:
int i = Adc_read();
I recommend you read through some C books and/or tutorials until you get a better handle on its syntax.
You solved my headache
Also, study "...Managing large projects...", in the tutorial forum.
2) WinAvr 20100110
A) Avr Dragon ver. 1
B) Avr MKII ISP, 2009 model
C) MKII JTAGICE ver. 1
