avr-gcc Feature: Inline asm and volatile
3 posts / 0 new
F'up of avr-gcc: New Features?
skeeve wrote:
Perhaps a mechanism for marking in-line assembly so that it will not be reordered with respect to volatile accesses.
Perhaps by putting volatile in the clobber list.
memory clobber is a bit of a bludgeon.
For that matter, it might be good to be able to "pass" a pointer into in-line assembly and tell the compiler that only its target might be clobbered.
This feature is already there.
Use "asm volatile" instead of "asm".
Notice that volatile is not a subset of a memory clobber, nor the other way round:
"¢ volatile actions are volatile actions
"¢ memory accesses are memory accesses
If a memory clobber is too intrusive, you may want to read GCC: Assembler Instructions with C Expression Operands that shows an example how to mark only a specific memory area as clobbered.
No. According to documentation,
using "asm volatile" does not cause avr-gcc to treat the in-line assembly as a volatile access.
It simply notifies the compiler that the in-line assembly does something useful the compiler does not know about.
It will not optimize away asm volatile that is reached.
Reordering is still possible
• volatile actions are volatile actions
• memory accesses are memory accesses
If I understand the magic example, a colon is missing.
Ja, a typo.
