I am interested in using the makefile from WinAVR to compile codes using Atmel AVR Toolchain (because there will be no longer any WinAVR releases), is it possible? Any way, is therea makefile tool for AVR Toolchain?
If yes (for WinAVR makefile), where can I find instructions on how to add Atmel AVR Toolchain necessary excusable files (that will be called by the makefile) in the environment variables path to be able to use the makefile with Atmel AVR Toolchain?
thanks
