New XMega instructions
5 posts / 0 new
I just tried some of the new XMega instructions in GSS-AS, and although they are not formatted in the IDE like valid instructions, there was no error on compile.
For instance, this "seemed" to work...
lac z,r16
Does this mean that GCC knows these instructions, or is it just ignoring them? Being away from my work, I can't test this on real hardware.
Brad
They seem to be there and do something ;-)
// uint8_t lac_test(uint8_t *, uint8_t);
.global lac_test
lac_test:
        movw    ZL,r24
        lac     Z, r22
        ld      r24,Z
        ret
Did you miss my post in another thread about this? The check in history for binutils shows the latest new instructions were added (by Eric Waddington in fact) seven months ago. So look for binutils major releases since that date and see if the one in AS6 is one. Personally I doubt it though I guess the most recent SP2 may have updated binutils?
I used the latest Atmel toolchain (3.4.1) for linux. It's based on binutils 2.22. But in avr-patches.tar.gz there is avr-patches/binutils/305-binutils-new-usb-insns.patch which contins
+AVR_INSN (xch,  "z,r", "1001001rrrrr0100", 1, AVR_ISA_XMEGAU, 0x9204)
+AVR_INSN (las,  "z,r", "1001001rrrrr0101", 1, AVR_ISA_XMEGAU, 0x9205)
+AVR_INSN (lac,  "z,r", "1001001rrrrr0110", 1, AVR_ISA_XMEGAU, 0x9206)
+AVR_INSN (lat,  "z,r", "1001001rrrrr0111", 1, AVR_ISA_XMEGAU, 0x9207)
If binutils accept the instructions, you can use them. You can also read a dump, e.g. generated with "avr-objdump -d ..." to see if the instructions are there.
avr-gcc does not know anything about these instructions, it's all Binutils, namely avr-as.
In official Binutils, it went upstream 2012-06-07 for 2.23: http://sourceware.org/ml/binutil...
