USB with 2 UART device ?
4 posts / 0 new
I'm starting to work on a hobby gps logger project. I want to be able to log the data to an SD card but also send it to my smartphone. Finally I was hoping that the device would have USB connection and act as a flash drive to pull the data from SD card as well as charge the battery. For this I want to use the LUFA library but I am not able to see any device that supports 2 UARTs for gps and bluetooth as well as USB. Is there such an 8 bit device? If no is there a way to achieve this, perhaps a low power bluetooth module that uses I2C anyone can recommend.
Currently I have the gps logging onto SD card running on a mega328p.
All I have is stk500 for programming and due to costs I was hoping I would not have to switch to Xmega.
Luco
Just bit-bang the lower traffic UART.
Or, sad to say, the U variety of Xmega probably is the easy answer. I'm sure there are devices with both USB and multiple UARTs.
Excellent idea, I've seen then Procyon library for bit bang uart too so shouldn't be hard to implement.
I've looked at this xmega chip http://www.atmel.ca/devices/ATXMEGA256A3BU.aspx and it does seem that using one would be excellent for me. The biggest problem is that all the packages I see are surface mount, is there a popular breakout board that will allow me to get started with the xmega?
I've used these in the past:
http://www.futurlec.com/SMD_Adap...
