SMT Equivalent of 2N3904 Transistor?
12 posts / 0 new
Dear all,
I'm looking for a SMT NPN transistor about the equivalent of the 2N3904, say in a SOT-23 package or similar? Normally I'm a software guy, but I am trying to create a really cheap design for my Dad's model train club :)
The original in a TO-92 package looks to go for under 10c in 1K volumes, which would be rather nice :)
Ideas?
Oops... I feel like a dill... the MMBT3904 is the ticket, but I'm still open to suggestions :)
2N2222A, 2N4124?
Google "General purpose NPN transistor" and see what happens.
I entered "NPN transistor" in one of digikeys searches and got 16,000+ possibilities :shock:
... which is precisely the problem :)
I actually like Digikey's search ( as distributor parametric searches go ). Drill down through it by adding requirements and sort by most important factor. The MMBT2222ALT3G from ON Semiconductors looks nice. It's got a 600mA rating, minimum gain of 100, comes in SOT-23 and is $0.10/25. Time to find... thirty seconds ( Discrete Semiconductors->Transistors (BJT) - Single, search for In-Stock, NPN, hfe > 100, surface mount - sort price ascending ).
Martin Jay McKee
As with most things in engineering, the answer is an unabashed, "It depends."
Any other particularly common ones that "everyone" uses?
BC547/548/549. In smd these are called BC847 etc. Their max Ic=100mA though.
I was wondering what they were called in SMT :)
-- Damien
Lovely huh ? Just add 300 to the partnumber.
BC847 in package SOT23 for the single ones, but there are also duals: BC847BPN in SC-88 (or SOT363)
I like these two (NPN/PNP), rated to 30v/700mA with high gain
http://www.unisonic.com.tw/datas...
Alex
"For every effect there is a root cause. Find and address the root cause rather than try to fix the effect, as there is no end to the latter."
Author Unknown
Fortunately, the design (bi-colour LED driver, with latch) is rather tolerant of low (and variable) gain :)
-- Damien
Basically you can use a higher base resistor and limit the current that the AVR pin has to provide.
This can be useful in some cases or maybe to reduce the consumption.
I find these transistor especially useful for some ARM mcu that can provide only 3mA per pin.
Alex
Author Unknown
