Using Eeprom of Atmega 32
18 posts / 0 new
Hii!
I want to Store and Read value from eeprom of Atmega32.I saw the tutorials Dean posted,but I am not able to apply.
I have to store the value of coordinate ex-(2,3) or (4,1) and than have to call it back in my program in later part.
Please provide help with code.
Thank you!
And are you working with assembler, BASIC, FORTH, C (which flavour)?
What does your code look like?
Ohh!Sorry
I am working in C(using Atmel studio 6).
I am making a Grid follower robot with some more features.As in it has to go to a Specified node sense the square cells colour around that node(for white or black patches)store number of white patches around that node and also has to store that node X coordinate.
Ex-if the initial node was (2,1).Bot would move to that coordinate,sense that coordinate surrounding squares and save number of white patches as Y1 and that coordinate X coordinate value as X1.Suppose it senses number of white patches as 3 than (X1,Y1)=(2,3).Now my bot has to do this for one more Node and get (X2,Y2) in similar fashion.
Than my bot has to move to (X1,Y1) and (X2,Y2).
Hope this information was useful.I know it's a bit confusing thou.
Please do tell me if you need any more information.
Thank you!
Then you should not have any problems using the built in AS6 toolchain's EEPROM functions.
What do you mean by
Doesn't the code compile? Doesn't work as expected?
If you write a small program where you simply write something to EEPROM and then read it back the we can see what you mean, we have no idea on what problems you are having with just "I am not able to apply". :-)
Hello! What's your problem? :)
I recommend you to take a look at datasheet. There are simple examples of routines to write and read a bytes in/from EEPROM.
What's range of your coordinates? It may take more than a byte for a coordinate. For example, if your X is changing from 1 to 1000 you must take two bytes for one coordinate. So, you must take four bytes for a node (x, y).
You use C, so you can declare following structure
typedef struct
uint8_t x; // it may be uint16_t
uint8_t y; // it may be uint16_t as well, or they may be             int16_t
} TNode;
// Declaration of node's coordinate
TNode node1;
TNode node2;
// Using
node1.x = 50;
a = node2.y; // 'a' is declared somewhere else
To write and read them you should use these functions
void writeNode( TNode node, uint16_t addr )
// some code you write by yourself
TNode readNode( uint16_t addr )
The 'tutorial' I have written isn't related directly to your problem. You have to solve writing/reading first. But this information may be useful for you in future.
Good luck!
What do you mean by
Actually I am having problem in writing code itself.(havn't reached till compiling part).I am not able to understand how to write code for storing two numbers of a coordinate ex-(2,3) and than calling these numbers as coordinate in later part of my program,so that my bot moves to these coordinates.
I am taking variable in my program to follow grid as:
i=2,j=2,i_dest=3,j_dest=2
Where at the beginning my i=0 and j=0 while above two values are my two NODES coordinate.Now when it reaches (2,2),I want to store this node x coordinate(i.e value of i) and number of white patches around this node as my y coordinate of new node(as I explained earlier),so my new coordinate for bot to move is (2,1) supposing there were 1 white patch around the node (2,2)...similarly I want to so this for my other node specified at first i'e (3,2).
Please give an example taking any of these nodes and writing it's program to read and store those coordinates value in eeprom.
Thank you! :D It was really helpfull,infact I guess this is the whole program for that.My coordinate range isn't too high it's from 0-9.I have few doubts thou:
1)void writeNode( TNode node, uint16_t addr )
In this I guess I have to just specify.
a)TNode node1 or node 2
b)uint16_t addr=uint16_t x or y
isn't? :?
I am cofused by "addr".
2)Can I take another structure in similar fashion for my other node too? :?
3)What did you exactly mean by "some code you write by yourself "?
Also you been of great help.So I am asking you for one more help here itseelf.
As you specified "a" in you code (a = node2.y; // 'a' is declared somewhere else).I am specifying it like following please check and give your valuable feed back if it's correct or not:
s1=read_adc(0)   /*I have put four sensors facing out on
                   the four corners of my robot.On state
                    shows black patch found.
                     (used digital sensor)*/
s2=read_adc(1)
s3=read_adc(2)
s4=read_adc(3)
if(s1==0&&s2==0&&s3==0&&s4==0)
a=4;                  //value of a=4 shows 4 white patch
else if(s1==1&&s2==0&&s3==0&&s4==0)
a=3;               //value of a=3 shows 3 white patch
else if(s1==1&&s2==1&&s3==0&&s4==0)
a=2;                //2 white patch found
else if(s1==1&&s2==1&&s3==1&&s4==0)
a=1;                //1 white patch
a=0;                  //no patch found
Same can be done to find black patches.
Please correct me if I am wrong any where.
Thank you for all your help. :D
Get a good book on C. You need to understand the difference between & and &&.
And the difference between = and ==.
Sorry about that.Please do tell me if there is any other mistakes. :oops:
I would guess the function 'read_adc' does more than just read the adc. Why not give it a more meaningful name?
Like?:D
I'm really sorry but then you should NOT attempt to write code for something complicated as "so that my bot moves to these coordinates".
Maybe start with something a lot SIMPLER.
I am not having problem in writing code so that my bot moves to coordinate,but I am having problem in writing code for storing and reading value in eeprom for my next destination coordinate.
Maybe I don't understand your problem :-)
Writing and reading to/from the EEPROM is pretty simple, just a matter of adding
#include
to your code.
Then use for example
uint8_t EEMEM Timeout_m, Timeout_s;
eeprom_write_byte((uint8_t*)(& Timeout_m),mm);	//Write Minutes to EEPROM
mm = eeprom_read_byte (& Timeout_m);
It seems to me like you are trying to figure out what data structures to use to store the data? The eeprom is sort of a serialized bunch of data, basically a big array or fifo. So if it were me, I'd design a convenient way to store the data in memory then serialize it out to eeprom as needed.
Am I understanding your question?
It should work - bot-thoughts.com
Thank you you got it this time...:D
but if you could see above,comments made by "haker_fox".I guess he gave me the proper answer to my queries,but I had few doubts in that,which I have mentioned in the second comment after his.
It would be great if you could answer those.
Also thank you for your reply.:D
Yes you are.:D
Could you please see my question in above post and tell a way to do that?with example codes?
Thank you..:D
