RJ45 Conector
3 posts / 0 new
I want to use a rj45 connector but confused with different types and pinouts. Here is a one which I can find:
http://www.javanelec.com/RJ00000...
first of all, what this POE thing? Does it provide power to the board and what is its use? If using POE, the RJ45 connector differs like this:
http://pinouts.ru/Net/poe_pinout...
http://www.allpinouts.org/index....(PoE)
I also found Ethernet shield for arduino which uses pinouts different from the above:
http://arduino.cc/en/uploads/Mai...
It mentions that it uses a standard RJ45 connector but I could not find one with the documented pinouts.
Can you shed some light on this?
Thanks.
Power Over Ethernet uses the same cabling as the Ethernet data cable to power up a device without extra power cable, the voltage and current are limited of course.
note that with POE the pinout isn't any different, only the pins have dual purpose. [you also need special electronics on the power supply side for it to work, as well as special magnetics]
