MicroWebServer, with SMTP email client
4 posts / 0 new
As file upload does not appear to work in the Projects area here is the .zip file of the project.
Original source code is at:
http://en.klinkerstein.m-faq.de/index.php/MicroWebServer, which is based on uIP.
[Edit]
After very occasionally seeing the DAC values being changed after just doing a port state change I have modified the code, so that DAC_data is local to CopyHpptData().
Read for history and the procedure for making the changes.
New code attached.
davef
Changed title to reflect new features.
Another year down the track and thanks to another software developer SMTP is now working using uIP v1.0 Main modifications in smtp.c Changes in the core code uip.c to eliminate complier warnings.
The attached file has the above webserver integrated with a SMTP email client.
Thanks for the modifications you have made. I will make it "public" on the uWebSrv homepage if you want.
Best Regards
Simon K.
HI,davef.
Based on what hardware platform? Specific hardware connection is what? Whether it can be released to the schematic or PCB.
