Anyone recognise this bootloader?
7 posts / 0 new
Client has a bootloader which accepts code download in the following form:
%!xxxx...
Where 'xxxx' is a hex address, and 512 bytes of data follow. Each byte is encoded as a pair of ASCII characters representing the Hex value.
Also:
%/xxxx
Erases 512 bytes of memory, starting at address 'xxxx'
And that's about all the information that seems to be available :shock: :!:
Do those forms look familiar to anyone :?:
Just wondering - in case it is a "known" product from somewhere...
awneil wrote:
%!xxxx...
Google tends to ignore the %! and just search for "xxxx" - which gives some, err, "intersting" results... :oops:
You could extract the code and search for any ASCII strings (assuming it might report some text messages?) then Google for those messages which might find the source.
If the chips weren't locked.
No, I don't recognise that format.
Mind you, it would be simple enough to create this format from a regular hex file.
Personally, I would replace the bootloader with a more conventional one.
awneil wrote:
... 512 bytes of data follow. Each byte is encoded as a pair of ASCII characters
Actually, I think it's 512 characters representing 256 bytes.
Well, you can just look at the %/xxxx lines and compare with the %!xxxx blocks.
I would guess that the strategy is byte orientsted, but you only need to inspect the %!0000 block and whether it is followed by a %/0100, %!0100.....
Either you have ISP access to your client's AVR and can install a regular bootloader.
Or you pre-process a regular HEX file into the required format. Then use the custom bootloader.
