What's this called and where do I get one?
5 posts / 0 new
Hi guys,
While dissasebmling a piece of equipment I came across an interesting part, something that I'd like to use in my own constructions.
But I can't name it properly in english. Attached is a crude drawing of it - it's obviously meant to mount a PCB onto something. It's a simple part, but it would replace all of those nasty L sections I used so far.
So, can anyone name this properly and if possible point me to a shop where they have these buggers?
David
Keystone Electronics...
http://www.keyelco.com/products/...
The keystone parts (and that drawing of yours) is for attaching screw terminals. Relatively high current.
I suppose you could also use them for attaching a PCB to a panel. And that's a very interesting use for them. Keystone parts are usually reasonably priced and available.
fwiw, these are also available for mechanical assembly.
(not sure of cost/availability)
http://www.pemnet.com/fastening_products/pdf/smtradata.pdf
-carl
Thanks for the info guys, much appreciated.
I don't know about those SMD parts - seems fishy to me, relying on copper as the main attatchement. The truhole ones seem less fishy to me.
There are also brackets like that with larger holes, commonly used for RCA jacks and coaxial power connectors and even BNC connectors. Bracket is one possible name for the thing.
