code strangely looping around and around
11 posts / 0 new
Hi Guy,
I have attached a complete program. It should connect to an sd card, and read an unsigned 8-bit mono.wav file from it then play it out of OCR0A. It used to do just that. I cant for the life of me work out whats going on, but firstly when I connect to the serial port that it should be printf-ing out of, it just repeats the first line it is supposed to print for ever, without moving on:
printing floats: 14.22, 3[00]
not even finishing printing the line, and never tries to connect to the sd card, and play the track.
Has anyone experienced anything like this before?
printf clobbering the stack perhaps ?
"Debugging is twice as hard as writing the code in the first place. Therefore, if you write the code as cleverly as possible, you are, by definition, not smart enough to debug it"
Hmm interesting. I obviosuly need to use progmem and will slim down my printf useage - probably wont use it at all.
Is there any way to move things to the heap? Like in C++ there is the "new" keyword?
How would that help? It would use the same amount of SRAM.
C uses malloc().
Steve A.
Did you enable watchdog? It appears your program is looping on a reset of some kind, so monitoring MCUSR might tell you whats reseting the micro, if it's a reset.
I find the code usually does whatever I've been dumb enough to tell it to do.
If you're using the watchdog, turn it off. It just confuses things.
Get rid of the printf's and use something simpler to track you app's progress.
I assume you are using the gnu c compiler. 99% of the avr c programmers in the world do. Is there a way of specifying the stack size in that compiler? In the Excellent Imagecraft compiler, there is a dialog box in the IDE to do this without a degree in Computer Science. Rant Off.
Anyone got some code I can "borrow" to replace printf but still be able to send floats to the serial?
I dont think Im using the watchdog... I never turned it on...
See the function dtostrf() in .
Why would you want to do that ? Is there a benefit to using anything less than all available memory ?
Sid
Life... is a state of mind
I would think because Imagecraft uses two stacks and the users have to guess how much they want for each of the stacks.
