Interrupt problem (again)
3 posts / 0 new
Now it is my turn to have interrupt problems with Studio 6. I haven't tried with Studio 4 so to be honest I can not say that it is a Studio 6 problem yet but I suspect that.
Problem is that if I run in full speed, everything works just fine. But if I single step, global interrupts is turned off.
After a long struggling I finally found that the problem was extremely simple. As soon as I single step using F11, global interrupt is turned off!!!
Using F10 work fine.
I can not even turn it on again manually by clicking in the I/O view.
/Edit. No it is worse. It turns off a little bit of here and there regardless if I am using F11 or F10.
My favorites:
1. My oscilloscope, Yokogawa DLM2024.
2. My soldering iron, Weller WD2M, WMRP+WMRT.
3. JTAGICE3 debugger.
There is a setting in the project setup that covers that. Normally, interupts are turned off, since you cannot single step, or you'd get perpetual ISR requests.
I cannot remember where it was, but there is a check box that defaults checked for "disable ISR's in single step" or something like that.
Going with what wires is saying, it's probably [/Tools/Options/Debugger/Mask interrupts while stepping]
The same setting seems to be available in the [/Debug/Options and Settings] dialog.
Sid
Life... is a state of mind
