bug in AVR 8-bit tool chain
15 posts / 0 new
The following attached programme works perfectly well if optimization is set to NONE. It does not works if optimization is set to optimize for size on an ATmega644P, under AVR studio5 (5.1.208) windows vista 6.0.6002 32 bits
The program deliver a sync (fb_sync) of value 3 at index (k) of 4 (5 on programme output).
The first thing that comes to mind is that the compiler may be optimizing your variables so have you tried to declare the variables as volatile to see if it works?
Also I don't see a super loop, as soon as the while is done you exit the main and this is not good.
Add a while(1); before the end of main.
Alex
"For every effect there is a root cause. Find and address the root cause rather than try to fix the effect, as there is no end to the latter."
Author Unknown
Alex
declare the variables as volatile works indeed.
The super loop is not an issue it is just a test sequence extracted from a more complex programm to find out what was wrong.
Pierre
Of-course the compiler optimizes most everything away.
A C compiler is allowed to optimize anything away that does not have any "real-world efects". In essence, since you never use neither fb_sync not k for anything then the compiler can remove those. This in turn will likely make the compiler see that it the array RDS_Val is no longer neded, so it throws that one out too.
Your program is just a slightly more convoluted version of this
unsigned char whatever;
  whatever = 1;
, the point being that since it, from the compilers point of view, does no meaningful thing most all of it can be optimized out.
is not an issue
But you haven't actually said what the "issue" is? o far we have:
and
with no further explanation of what "perfectly well" and "not works" actually mean?
Clearly when you snip small sequences out of a larger code like this the optimiser is completely at liberty to cut the code to shreds.
OP stated it is a cut-out from a larger program. I believe the OP thinks there is an error in the short snippet of code above - i.e. in the larger program it does not behave as intended.
Now the OP cuts out this piece of code into a small test project, and immediately is tripped on the fact that since fb_sync is no longer used for anything meaningful the optimizer chews up the whole test program.
Peter! Make your two variables fb_sync and k 'volatile' and you will be much better off simulating this code snippet.
clawson wrote:
is not an issue
and
Thanks 10k super freak for your time, but you should read the complete sequence, alexan_e suggested to declare the variable as volatile, which I tested and answered to let him know that with the volatile declarationb my program works i.E. it delivers what I was expecting.
If I do snip a small sequence it is because my big programm (87% of RAM) caused me troubles and I wanted to find out why!!
(87% of RAM)
Well that's a danger sign right there - anything over about 75% is in "dangerous" territory unless you have almost everything global and don't use automatics. While it's not an exact science as it does depend on the amount of use you make of locals it's generally been shown here that 75% is usually about the usable limit.
I'd paint the stack and then watch it in a debugger.
I've built your code and single stepped it (simulator) and I cannot see anything untoward happening.
Have you changed the optimization parameter from optimize for size to no optimization. That is how, in the AVR studio simulator, I detected what I thought was a bug.
Now we know the answer: declare as volatile
I fear you misunderstand. "volatile" just over-rides optimisation and prevents too much of your example being thrown away but that does not explain why the code might misbehave "in-situ" where it occurs in a larger program where the sequence would be valid.
I am not an expert but I don't understand why either.
> quote: "A C compiler is allowed to optimize anything away that does not have any "real-world efects".
Except that the variable feedback_sync is used even if only locally in small portion of the overall code.
I can send you the complete code should you wish.
Not in the example program you posted above, and that is the only thing we can relate to.
I do not think that people will be very interested in getting the complete code for your application to analyze. That would put the workload of isolating the problem you are seeing on us. What you should do is to post a minimal but still buildable and runnable program that people here can look at.
Creating that minimal demonstrator is a valuable exercise for you. And it is also not unlikely that you in the process will get clues enough to solve the problem yourself.
If I understand it correctly, the code you posted here was an attempt to solve a problem you had - but instead you ran into another problem with it, i.e. that it was too much of a reduvtion for it to work as a debugging attempt. The optimizer ate it all.
You could try to cut away part after part of your application, starting with those that are farthest from the original problem you experienced. For each cut, you check that you can still provoke the problem you have. At some point you are left with a rather small piece of code to debug. If you fail to get to the problem yourself at that point then post the thing here.
Before you do anything read this https://www.avrfreaks.net/index.p...
It may not fix things but who knows.
Thanks for advice, but it is not the solution
Pierre
You could try to cut away part after part of your application, ...At some point you are left with a rather small piece of code to debug. If you fail to get to the problem yourself at that point then post the thing here.
No, it is exactly the same issue. I add an attachment which is the issue I try to solve, obtained by cutting away chunk of the complete programme.
It is exactly what I have done to find out the issue with optimization.
> If you fail to get to the problem yourself at that point then post the thing here:
See attachment
As a reminder issue is in m4.c/run_m4_specific. The loop while should get out with fb_sync=3 at k = 5 which does not happen if optimization for size is selected.
