EEprom decalration occupy SRAM memory
4 posts / 0 new
I use at90can128 with optimizer on "“0S and want to use the eeprom
In .h file
typedef struct
uint32_t VAL;
uint16_t CRC;
}EEPROM_32;
In C file I declare my EE_SCHEDULE_INTERVAL
EEPROM_32 EEMEM EE_SCHEDULE_INTERVALL[3] = {
{0x00005460,0xBF04},
{0x00005460,0xBF04}
When compiling the Data memory usage increase equal to the eeprom usage. So it seems like declaring of a EEPROM struct occupies SRAM memory.
What do I do wrong?
Br Leif G
That's a known bug in AS6 memory usage reporting. If you want the true figure use avr-size outside of AS6 (or as a post build step). Because of the faultin previous threads Atmel have given a way to switch off their own, errant, size reporting but my brain is too addled to remember exactly what the incantation is right now - a search will likely find it.
As a test I built this:
#include
#include
typedef struct
	uint32_t VAL;
	uint16_t CRC;
}EEPROM_32;
{0x00005460,0xBF04}
int main(void) {
	while (1) {
and AS6 said this:
		"C:\Program Files\Atmel\Atmel Studio 6.0\extensions\Atmel\AVRGCC\3.4.0.65\AVRToolchain\bin\avr-size.exe" "GccApplication1.elf"
		   text	   data	    bss	    dec	    hex	filename
		     40	     18	      0	     58	     3a	GccApplication1.elf
	Done executing task "RunCompilerTask".
	Using "RunOutputFileVerifyTask" task from assembly "C:\Program Files\Atmel\Atmel Studio 6.0\Vs\Compiler.Task.dll".
	Task "RunOutputFileVerifyTask"
				Program Memory Usage 	:	40 bytes   0.2 % Full
				Data Memory Usage 		:	18 bytes   1.8 % Full
				EEPROM Memory Usage 	:	18 bytes   3.5 % Full
But when I run avr-size separately I get:
C:\Documents and Settings\asl\My Documents\Atmel Studio\GccApplication1\GccApplication1\Debug>avr-size -C --mcu=atmega16
 GccApplication1.elf
AVR Memory Usage
Device: atmega16
Program:      40 bytes (0.2% Full)
(.text + .data + .bootloader)
Data:          0 bytes (0.0% Full)
(.data + .bss + .noinit)
EEPROM:       18 bytes (3.5% Full)
(.eeprom)
which is the correct answer.
It looks like a "feature" of AS6.
				Program Memory Usage 	:	160 bytes   1.0 % Full
This is what AS4 produces:
Device: atmega169p
Program:     122 bytes (0.7% Full)
(.eeprom)
Don't worry about it. You may have to manually subtract eeprom size from SRAM.
I appreciate the fast response, I will ignore this and do it manualy, The output you refer to is exact what I see her. Thanks.
Br Leif G
