calculate the difference in seconds between two date & t
8 posts / 0 new
Dear Friends,
I want to calculate the difference in seconds between two date and time. As for example I have two dates and times like
2012.09.28 at 13:30:00
2017.11.25 at 16:32:55
Now I want to know how much seconds are there between these two data and time. I use C as programming language.
I also want to say that I use AVR uC and as compiler I use mikroC PRO for AVR. In mikroC there is built in library to do the job. But I do not want to use it. I want to build my own algorithm.
Please help me.
Kind regards
Hasan
Use the mktime function from to calculate the number of seconds since the epoch for each date. After that just substract the values.
Daniel Campora http://www.wipy.io
is it in ATMEL STUDIO?
If you program avr32 then yes, if you program avr8 then no.
It's really the source of mktime() you'd want to get access to. The source of the C library should be available somewhere as I assume it's published under an open license.
Failing that there have been a number of threads in AVR Forum discussing time.h and the functions it provides access to. Maybe search those out?
Then why are you posting in the AVR Studio forum (AVRStudio uses the avr-gcc compiler)? And since you want to write your own, then the compiler you are using is irrelevant.
Steve A.
Hmmm--I think I posted my "make Unix-style timestamp form BCD date/time from RTC" recently. And there were other suggestions in the same thread. Searching...
difference between any two dates/times is a quite complex algorithm. Not prudent to DIY.
If the date range is limited to say, this century, it's not so bad; just leap years and leap seconds to deal with.
Dear
Steve A
I use mikroC PRO and made some products for my company. But now a days I am shifting to ATMEL STUDIO6.
Thnx All
