2's Complement
23 posts / 0 new
Hi All
I am trying to read a temperature off a I2C Chip
the data sheet says
5.4.1 DIE_TEMP (0x0F)
Temperature °C expressed as an 8-bit 2's complement number, however, the temperature is not trimmed for offset and the
compensation for offset must be done in user application. The sensitivity of the temperature reading is correct. Note: The register
allows for temperatures from -128°C to 127°C but the output range is from -40°C to 125°C
I am getting 250 out of it, if i do
temperature= ~temperature;
I get 5,
neither is correct, and if I do the second option, the temp goes down when I raise the die temperature.
the device is a freescale MAG3110
Phil
_________________________________
www.proficnc.com
Go Aussie Go!!!
Self solved, helps if you set the variable to a (signed) char, rather than an unsigned char :)
oops :)
www.proficnc.com
Go Aussie Go!!!
That's ok, it's good to see your face. :wink: :D
You should use unsigned char, not char.
Steve A.
I miss something,
I was under the assumption that a char is by default unsigned as it was from "character" I do not have a manual at hand here, but wonder if I got it wrong....
int is signed by default
char is unsigned by default
byte is unsigned by default
for the record I always try to use uintx_t and intx_t for defining my variables for a simple sole like me that keeps it as simple as possible 8)
To get an output range of -128 to 127 he should use signed char, or a type to that effect.
Given that the output range is actually 40-125 it doesn't matter one way or the other.
Sid
Life... is a state of mind
This comes up about once a week here. C has THREE distinct char types:
char
unsigned char
signed char
char is neither signed nor unsigned. Always pick the appropriate one.
If dealing with characters/strings use char.
If holding 8bits as 0..255 use unsigned char
If holding 8bits as -128..+127 use signed char
Gcc does have a command line switch that most Makefiles and AS4/AS5/AS6 use that is -funsigned-char for which the manual says:
-funsigned-char
Let the type char be unsigned, like unsigned char.
Each kind of machine has a default for what char should be. It is either like unsigned char by default or like signed char by default.
Ideally, a portable program should always use signed char or unsigned char when it depends on the signedness of an object. But many programs have been written to use plain char and expect it to be signed, or expect it to be unsigned, depending on the machines they were written for. This option, and its inverse, let you make such a program work with the opposite default.
The type char is always a distinct type from each of signed char or unsigned char, even though its behavior is always just like one of those two.
BTW Google hit this which looks interesting:
http://www.network-theory.co.uk/...
Thanks Larry :)
I've still been around lurking at the edges, just been a crazy last few months.
And yes, a good old signed char did the job.
Phil
www.proficnc.com
Go Aussie Go!!!
Sorry, I meant signed char. I guess I am just not used to writing signed since this is the only place that it is really used and I use int8_t.
Steve A.
clawson wrote:
gcc does have a command line switch that most Makefiles and AS4/AS5/AS6 use that is -funsigned-char
Using -f[no-][un]signed-char is a really bad idea bacause it changes the application binary interface (ABI).
It's bad because linking object with different ABIs together may result in non-functional code. Notice that objects that come from a library are only save if this option is a multilib option, i.e. the tools pick the correct ABI flavor of libc/libm/libgcc depending no that option.
None of the mentioned options is a multilib option.
And most users don't compile their own standard libraries with their private options to render the library ABI compliant.
Same here - this is the only platform I have worked on where char is not signed by default. That bit me enough that I usually add this line close to the top of my source files:
#define char use__int8_t__not__char
Sid
But you want to use char when it really is a character. I only use int8_t when it is a number.
Steve A.
You have a point there, I remove it in those cases. Most of the time it is a useful reminder, though.
Sid
My habit
always be explicit in declarations:
uint8_t for example
don't assume the compiler config is any particular value.
use char only for 7 bit ASCII.
Anything that is arithmetic in nature, use unsigned char or uint8_t from stddefs.h
If you're not certain about fitting ranges into 8 bits, use an uint16_t or uint32_t or int16_t or int32_t (signed). Avoid 32 bit integers, and of course floating point wherever possible on 8 bitters.
That's intriguing. Never realised that. As I say most build systems seem to default to specifying -funsigned-char, do you know if that's what's been used in the generation of libc/AVR-LibC
What does the compiler default to ?
As for libraries, I don't see how it would matter one way or the other.
Assuming the libraries were built with types suitable for what the library does, it doesn't matter one bit whether the caller uses signed or unsigned char for arguments.
Sid
But if you just declare "char" with no "signed or unsigned" what does it default to?
www.proficnc.com
Go Aussie Go!!!
Define "it".
I was (rhetorically) asking what the compiler defaults to. Any sensible compiler will default to signed for char, just like it will for any other integer type.
Some build environments do, for reasons that are beyond me, override this default with their own defaults.
Sid
It = char
www.proficnc.com
Go Aussie Go!!!
What the compiler default is depends on how the compiler was configured when it was built. The AS6 compiler says:
C:\Program Files\Atmel\Atmel Studio 6.0\extensions\Atmel\AVRGCC\3.4.0.65\AVRToolchain\libexec\gcc\avr\4.6.2>.\CC1 --help  | grep "signed-char"
  -fsigned-char                         [enabled]
  -funsigned-char                       [disabled]
so it's defaulting to "signed char" for "char". Doing the same on WinAVR20100110 produces:
E:\WinAVR-20100110\libexec\gcc\avr\4.3.3>.\cc1 --help | grep "signed-char"
  -fsigned-char
  -funsigned-char
which suggests neither was explicitly specified when the compiler was built.
In other words, don't leave it to the compiler, specify the signed or unsigned and be sure :)
www.proficnc.com
Go Aussie Go!!!
If you use signed char when you dont have to (all terms in expression are > 0) you might get an extra branch instruction in a relational expression to deal with the sign bit. That's the only down side I can think of.
The C standard says it is implementation defined, thut it's up to the implementation, i.e. the compiler in this case. The compiler, in turn, has to follow the ABI which must specify if char operates as signed or as unsigned.
If an ABI is sloppy and does not mention signedness of char, you have to read the compiler sources (provided they are available to you) or ask the support. In the case of avr-gcc, DEFAULT_SIGNED_CHAR is define'd to 1 in GCC's avr.h.
As just mentioned, this is up to the ABI, just like sizeof (void*), sizeof (int), signedness of plain int bitfields, number of significant initial letters in symbol names, alignment of data and composites, endianess, stack and frame layout, parameter and return value passing, the result of pointer-to-int casts (and vice versa), how to search for #include and #include "foo", the integer type compatible with each enumeration, ...
