Inline assembly with xmega
11 posts / 0 new
I have a problem with inline assembly
I have a naked isr that works fine with a AT90USB646
ISR(USART1_RX_vect, ISR_NAKED)
asm (
"	lds	r17,%[udr1]							\n\t"
"	reti									\n\t"
[udr1] "M" (_SFR_MEM_ADDR(UDR1))
"memory"
Then I have to port it to an xmega device ATxmega128A1
ISR(USARTC0_RXC_vect, ISR_NAKED)
asm (
"	lds r17,%[udr]						\n\t"
"	reti									\n\t"
[udr] "M" (_SFR_MEM_ADDR(USARTC0_DATA))
"memory"
But studio 4 give me this error :
warning: asm operand 0 probably doesn't match constraints
when I try to replace the LDS line by :
"	lds		r17,USARTC0_DATA 				\n\t"
I have this error
undefined reference to `USARTC0_DATA'
USARTC0_DATA and UDR1 is defined as this in their respected io.h
#define USARTC0_DATA  _SFR_MEM8(0x08A0)
#define UDR1    _SFR_MEM8(0XCE)
This works :
"	lds		r17,0x08A0 						\n\t"
But not this :
#define USARTC0_DATA_addr	0x08A0
"lds		r17,USARTC0_DATA_addr 				\n\t"
Sometimes in my tests he said me :
lvalue required as unary '&' operand
Do someone know what I have to write in my interrupt code to make it run ?
I have read the avrlibc manual, but it is not very clear. And there is no sts lds example with xmega.
Best Regards.
Doom
AVR inside
Don't use conatraint "M". Use "n" instead.
USARTC0_DATA is just a define to an integer (address), thus you have no symbol you can refer from asm.
#define replaces text in the source file but not inside of strings, therefore define does not work is you intend it.
Because all addresses in avr/io.g are RAM addresses, you can use the neat &USARTC0_DATA instead of _SFR_MEM_ADDR(USARTC0_DATA).
If you are writing a complete ISR() then what's the advantage of using inline asm() in C? Why not put the whole ISR in a .S file and write clean Asm source like God intended?
Simply accessing C variables from my asm ?
AVR inside
Good job, it compiles well !!!
But how can I find this as it seems not to be in the documentation (http://savannah.nongnu.org/download/avr-libc/avr-libc-user-manual-1.8.0.pdf.bz2).
In the inline assembly cookbook p42, the little 'n' constraint does not exist.
And on the next page, the LDS instruction is defined like this :
lds r, label
Hard to find the 'n' constraint !
So, big big thanks for you.
(if you know a documentation that explains all inline assembly, 'Je suis preneur' as we say in french)
Best regards
AVR inside
Eh? It's just as easy to access C variables from Asm as it is in C.
// file1.c
#include
uint16_t var = 12345;
void asm_func(void);
int main(void) {
  DDRB = 0xFF;
  DDRD = 0xFF;
  asm_func();
// file2.S
#define __SFR_OFFSET 0
#include
.global asm_func
.extern var
asm_func:
  lds R24,var
  lds R25,var+1
  out PORTB, R24
  out PORTD, R25
  ret
This writes 0x39 to PORTB and 0x30 to PORTD.
When I wrote this code years ago, I have just find this example with the BEER-WARE licence
And in this example, the variables are in registers. Has I am using all possibly register in an other hyper fast interrupt, I can't waste register for this, and so I use inline assembly.
Next time, if I can, I will use the S way as it seems to be more simple.
Thanks for your example.
This example is not in the documentation avrlibc. Why ? Is it possible to add it ?
Best Regards
AVR inside
I tried to write some inline assembly once.
my head hurt a lot and the code would not compile.
Using the info in avr-libc I was able to write a .S file that worked and was readable.
regards
Greg
Not that example but AVR-LibC docs have this:
The point I was making above was how a C variable could be accessed by .S code. In the manual example you see 'pwm_incoming' and 'intbits' shared between the C (where they are defined) and the .S
It is the link I give you, but you are right.
I have read to quickly...
AVR inside
n is documented in the GCC manuals just like other machine independent constraints like s, i, r, or m.
