What does opcode 0xFFFF actually do?
14 posts / 0 new
I know that opcode 0xFFFF doesn't really exist, but in some cases (rare, thankfully) where a firmware upload through a bootloader has gone wrong, the CPU must eventually stumble upon the 0xFFFF "opcode".
I have checked the datasheets, searched this forum, and googled the topic. But I still haven't found what I'm looking for. (Sorry about that, Bono. Couldn't resist.)
So, I'm asking you guys: Anybody know what an AVR will do when trying to process opcode FFFF? Skip it and read the next, like a NOP? Freeze? Reset?
Best regards,
ErikT
You're absolutely right. This member is stupid. Please help.
Search for a thread by "Brutte" where this was explored and explained previously.
EDIT: OK it is "sbrs r31,7" so how it behaves depends on what's in bit 7 of R31. It either executes every opcode or every second one.
EDIT2: actually the discovery seems to date back to at least 2004: https://www.avrfreaks.net/index.p...
Step through it with JTAG and see for yourself.
No. I have not bothered to.
At a guess, it behaves as a NOP. Most modern CPUs will do nothing for an 'un-implemented' opcode.
In the old days, a 6502 would do 'strange things'.
A 68000 would raise an exception for 'line-F' and 'line-A' opcodes. This could be used to 'expand' the 'features' like a Maths-co-processor.
Untested. Reaching into my distant memory.
Nope this was the common misconception. It is actually SBRS R31,7. While you might have spotted this with JTAG it would be pretty fortuitous to see that bit 7 of R31 was relevant!
IIRC the Apple Macintosh used these opcodes as entry points into the OS.
It's funny how the AVR studio 4.16 disassembler does not know about opcode 0xFFFF. SBRS R31,7 seems like a valid instruction.
Well just to confuse things further the current opcode manual says the bit pattern for SBRS is:
1111 111r rrrr 0bbb
So while rrrrr and bbb may be 1's that has a 0 in it.
Officially the SBRS opcode is : 1111 111r rrrr 0bbb
So perhaps bit3 is treated as don't care.
If if does behave as SBRS, then an "empty" mega128 would take 65536 cycles to get back to where it started. i.e. 4.096ms @ 16MHz
The SBRS would either go in 2-word steps @ 2 cycles or 1-word steps @ 1 cycle. i.e. "almost" the same as an even number of NOPs.
So a human is never going to notice whether a bootloader starts directly with BOOTRST, or 4ms 'late' because it skipped throgh an 'empty' application.
Ooooh. That's weird. Sounds like somebody cut a corner somewhere.
Thanks for your "Brutte" tip. Apparently, the forum search thing doesn't find articles with 0xFFFF, when I search for FFFF. Got it now.
Just to note that the official NOP opcode is
0000 0000 0000 0000
It would be a simple matter with a utility such as Srecord to have "blank areas" in a .hex padded to hold 0x0000 rather than just rely on the 0xFFFF erased default value in flash if one was really paranoid about such things.
In what sense? What do you think should have been done?
If CPU designers did not skimp on the full opcode decoding the Z80 would never have got the IXH/IXL/IYH/IYL instructions!
http://www.z80.info/z80undoc3.txt
The plan was that the DD/FD prefixes (for example) would just cause an HL opcode to act on IX or IY but it turns out that because of incomplete decode it also affects all the separate H and L opcodes to allowing for IXH/IXL/IYH/IYL operations.
Not that I know exactly what that means, but I understand that it has something to do with "accidental", but useful, instructions.
I think it is different with the 0xFFFF in the AVR. You don't get an extra, useful instruction. You rather get a "maybe-NOP", and you may get the microcontroller to reset, if you don't have bootloader code, or something else placed in the higher end of the flash.
Maybe it's just me, but I'd rather have the microcontroller freeze when hitting a 0xFFFF. Better that, than crashing into some data, or into the bootloader.
It's an unfortunate error in the initial microcode, I wish they would have fixed it in newer AVR's when they changed the documentation. As it stands now, if using a bootloader, it is adviseable to place a NOP right before the bootloader vector table to ensure that the bootloader reset vector is not skipped.
It's not "HCF" (Halt and Catch Fire)?
