what transistor for ignition coil?
7 posts / 0 new
Hello
I have finish a project with avr ,electronic ignition with adjustable advance, for one cylinder engine.
The ignition coil from this engines is connected to ground and ignition module switching the positive.
I have make my test with standard bipolar transistor and work but not as we like to work ,we don't have enough current to coil ,comparing with oem ignition module.
I am thinking to use p channel mosfet transistor, because mosfet have low resistance from source to drain, in parallel but i don't know what type to use there are a million types out there.
Avr give high output for every pulse so I use first npn transistor to drive power pnp transitor or p channel mosfet
Thank you
There are devices specific for ignition applications. Bosch, ST and infineon have such items. If you have a look at the megasquirt website, there is much discussion about driving ignition coils.
FYI, normally the 0V side of the coil is switched so you would use a npn or n channel mosfet/igbt.
I have found many special design transistor for ifnition coil but all is npn.
I have to swtch the positive side so i need pnp
Why do you want to switch the positive when the common method is to switch the negative? The lack of specialist devices suggest anything to you?
All the mini bikes like honda inovva ,lifan motors yamaha etc on little bikes use possitive switching side.
In my bike i can make it with negative no problem for me but what to tell a customer who will buy my electric module to change the coil connection?
I have to make it plug and play.
thanks rickb i didnt think to search before for cdi.
