What is the best modulation to choose when targeting maximum range in sub-1G?
My (basic) knowledge tells me that I should go for BPSK as the receiver has a higher senisitvity. I can easily cope with the lower transmission rate.
Are there any other advantages with OQPSK? The only one I can think of is that it uses less RF bandwidth and might be less sensitive of being jammed by nearby transmitters.
