8X8 RGB smooth led display Binary Code Modulation possible?
2 posts / 0 new
I want to make an 8 by 8 rgb led screen and was wondering if a 20MHz avr would be fast enough. The idea is to read data from SD card and use binary code modulation (BCM) as described in http://www.batsocks.co.uk/readme/art_bcm_1.htm to update the display. I am hoping to get 10 - 24 fps (smooth movement) and no flickering. So say I aim for 20 fps and 10 BCM cycles per frame at 8 bit resolution. Thus to update the 4 ports controlling the leds and read data from sd card ill have 20 MHz / (20*10*8 ) = 12500 cycles. Is it realistic to do all that in so few cycles? Also I have not used BCM before, how many BCM cycles is required for no flickering?
Thanks in advance
Luco
It is not that simple. The number of clock cycles between the port updates is not constant. With a 8 bit resolution you have 8 different numbers of clocks. For (approx) 200 Hz BCM frequency and 20 MHz clock frequency they are:
390, 780, 1560, 3120, 6240, 12480, 24960, and 49920.
Stefan Ernst
