Statement has no effect PSTR - ?
24 posts / 0 new
Hi Guys,
I'd like to ask you for the problem you could came across. In my program I tried to use following:
1. strcasecmp_P( CmndPtr, PSTR( "string" )
2. strpbrk_P(Command, PSTR(":?"))
3.strtok_rP( Command, PSTR(":"), &Addr);
The 1st and 2nd line gave warning: "Statement has no effect 'PSTR("...") whilst the 3rd did NOT. What is strange, my private functions which use the flash mem do accept PSTR macro. Where is the problem? robiw
If you don't use the result of the comparison, the comparison can be thrown away.
strtok has side effects and cannot be optimized out alone from the fact that the return value us unused.
In fact I use all of the function's results in "if" statements. So, the problem seems to be different. Robiw
In fact I use the result of this function in "if" statement.
This is not a quiz site. Don't play guessing games with us. Show smallest complete program that displays the problem you want to discuss.
(Don't forget to use CODE tags to avoid the forum software replacing bi- and -trigraphs with emoticons etc.)
The quality of the answers you get is highly correlated to the quality of your question.
ok. You're right but it is not the matter to be so nervous. I'd like to simplyfy the problem. I'm in fact young user but not young programmer. So, be more flexible, please. Robiw
I am not nervous at all. I am simply stating that in order to get a good answer you need to supply full detail of the problem. E.g. instead of saying
why not simply be unambiguous and show some actual code?
It was you who asked
and if you want a good and definite answer to that it is up to you to supply information enough.
Suppose I ask you this: "I turn the ignition key on my car but it won't start. Where is the problem?"
To be honest, it was a bit hard to post my question and attach code from my Nokia's browser ;-). Coming back to the problem, the code is:
if ( strpbrk_P(Command, PSTR(":?")))... //it makes a warning...
if ( strcasecmp_P( CmndPtr, PSTR("AT+ADC") ) == 0 )... //it makes a warning too...
CmndPtr = strtok_rP( Command, PSTR(":"), &Addr)  //This, for instance doesn't make a warning...
robiw
PS.
The warning: Statement has no effect PSTR... I can attach full code if it is needed...
Obviously it is not practical to post code from a Nokia. Simply say this in your first post: "I have this problem ... (I am not at my PC at the moment)"
However you can post a minimal compilable program from your PC when convenient. Then I guess you will get an answer very promptly.
OK, we will wait until you are at your AVR development machine where you have better opportunities to make extensive posts.
Again, the best you can do is to cut your code down to an absolute minimum that still displays the warnings, and then post that code here.
As an indicator of what I am talking about, I tried this minimal test:
#include
#include
// Some dummy command
char * Command = "Ho-Hum!";
         // Just do something involving volatile so as not to get optimized out
         PORTB = 0xFF;
and this produces no warning when building.
There are no warnings.
I allowed to transform your, well "text", to a piece of valid C code.
After fixing dozens of syntax errors, and compiling with
    avr-gcc -mmcu=atmega8 foo.c -fsyntax-only -std=c99 -pedantic -W -Wall -Wextra
No error, no warning.
Your problem in somewhere else, outside that snippet or in the ... that you added for extra obfuscation.
Still not nervous, but somehow flabbergasted that you are still not convinced that posting some complete code will be the best way to get help. :roll:
What you should not do is to post your actual application code, not cut down to minimal. It is your job to isolate the problem as best you can, and then we will be interested in helping you. Don't show us several hundred lines of code. Show us something like a "twenty-liner" where you have isolated the problem.
(Chances are that you will discover the problem yourself when cutting your code down...)
Hi Guys,
Now, I'm at my PC ;-). The simplified code which causes warnings as well:
#include
#include
#include
#include
volatile uint8_t ReceivedCommands;
char Command[10];
  char *CmndPtr;
  char *Addr;
	if( ReceivedCommands )
         if ( strpbrk_P(Command, PSTR(":?"))) //Warning: Statement has no effect 'PSTR(":?")'
	  CmndPtr = strtok_rP( Command, PSTR(":"), &Addr);
        if ( strcasecmp_P( CmndPtr, PSTR("AT+ADC") ) == 0 ) PORTB = 0xFF;  //Warning: Statement has no effect 'PSTR("AT+ADC")'
What is more, and what might seem to be a bit stupid, I have the impression that the problems appeared since I reinstall Eclipse IDE - they started being highlighted ("yellow bugs") in the edit window. Best regards...robiw
#include
extern void initstdio(void);
char Command[40];
	char *CmndPtr;
	char *Addr;
	initstdio();
		printf_P(PSTR("Enter command :"));
		gets(Command);
		ReceivedCommands = 1;
				printf("cmdptr = \"% s\"\r\n", CmndPtr);
				    printf_P(PSTR("strcase found \r\n"));
			ReceivedCommands = 0;
Now, if you want to give some test strings, you can say what result you want.
I just did a test build of your code. No warnings here...
Give us the following information:
- What AVR model are you building for?
- What version of avr-gcc are you using?
So is it actually a warning coming from the compiler, or merely a warning of the IDE?
I bet it is the latter, because the gcc warning I know is "statement with no effect" (note the "with" instead of "has") and it does not come with a quote of the statement.
Stefan Ernst
Hi Colleagues,
I attached image from my PC. As you can see Console tab has no problems whilst Error tab has one error and two warnings. I think, it can come from IDE Eclipse, not from compiler but why? The last time I use the IDE (before reinstalling to the same) there were no problems. robiw
If you look at the PSTR macro you will see that it ends with "&__c[0];})". Someone, who don't know that a GCC extension is used here to "return" something from a code block, could think that it is a statement with no effect. Why Eclipse doesn't show the warning for all instances of PSTR then? Who knows.
Stefan Ernst
But the "return" is used withing all these str functions, so? robiw
But the "return" itself is a statement with no effect. It is like this (assigning 3 to var):
var = ({uint8_t x = 1; x+2;});
Within standard C a "x+2;" is a statement with no effect.
Stefan Ernst
Sorry, I can't catch it. So, is there a real problem or only the theoretical one? robiw
The message you are seeing is coming from the module in Eclipse that evaluates code while you type. It is not the compiler emitting these messages but a different piece of software.
The final say on if there is a problem or not should be left to the compiler.
Since you say that you have re-installed Eclipse and then started getting these messages then obviously something has changed as compared to your previous installation. Go back to your notes on what version you had installed, and what you have installed now and compare. This might give a hint.
And since this has nothing to do with the avr-gcc compiler, and probably everything to do with the C language module in Eclipse, then this ought to be a generic problem for any C development in Eclipse, not only AVRs. So... I just tested a very quick Google for "statement has no effect Eclipse GCC" and I get many hits. I suggest you do that Googling, and study the results. I see indications that adding a pair of parenthesis might make the bogus warning go away.
No problem at all (apart from a false warning made by Eclipse).
Stefan Ernst
If you look at the macro expanded code everything will be clear :-). Or not :-(
     if ( strpbrk_P(Command, (__extension__({static char __c[] __attribute__((__progmem__)) = (":?"); &__c[0];}))))
  CmndPtr = strtok_rP( Command, (__extension__({static char __c[] __attribute__((__progmem__)) = (":"); &__c[0];})), &Addr);
  if ( strcasecmp_P( CmndPtr, (__extension__({static char __c[] __attribute__((__progmem__)) = ("AT+ADC"); &__c[0];})) ) == 0 ) (*(volatile uint8_t *)((0x18) + 0x20)) = 0xFF;
:wink:
Hi Colleagues,
Thanks a lot for the answers! In fact, I have been programmed AVR micro since few years but with basic (I know, it was mistake ;-)) and had to change many of my habits ;-). The Eclipse's re-installation was not in fact re-installation because Eclipse doesn't need to be installed, only unpacked :-). So, I don't know where the problem comes from. Nevermind. I just change my Juno to Indigo Eclipse. The expanded macro code above doesn't make me fell the problem :-(...best regards...robiw
