Working with multiple instances of Studio 6
12 posts / 0 new
Hi all!
I have the following problem:
I'm working on a board including two different controllers. An AT32UC3A0512 and an ATXMega32A4. The AT32 is programmed with a JTAGICEMKII, the ATXMega with a AVR ONE!. I have two instances of the AVR Studio 6 opened, to see both project at the same time. The two controllers have to communicate to each other, as well as to other external devices, so it is an interactive process to write both codes. So far, so good.
What's driving me nuts is the programming of the devices, because the programming dialog seems to have only one instance. So I have always to change all the device and path fields when "switch" to the "other" device.
Isn't there a better way!?
regards,
Thomas
You could work with debugging on one board that should work.
Yes, it is a pain the the rectum. Atmel should fix it so that each project remembers the settings for the programming. Good luck convincing Atmel that it's a good idea, considering they believe the programming tool MUST be modal.
I am experimenting with using Debug->Start Without Debugging as a shortcut. I have assigned the key sequence of Ctrl-Shift-Backspace as a quick way to program. I haven't fully tested what happens when switching projects, but it may work.
I know it's a bit extreme but you could use VirtualBox to run a separate virtual machine with another copy of Windows then it'd be like you had to PCs on the one piece of hardware. You will need a Windows installation disk to achieve this though.
Can't you use atprogram on one of them?
Surely he wants to debug them not just program them? Otherwise why not just program them sequentially?
It seems he wants to program them both. Debugging in multiple instances is no problem AFAIK while it is not possible to open more than one programming window(had that problem aswell)
Oh! This could be a good idea. I could define a program command for one of the cotrollers.
I will check it out tomorrow.
regards,
Thomas
You mean in a jtag chain? Normally it's a good idea, but the ATXMega32A4 has no jtag interface. Only PDI.
regards,
Thomas
Hi all!
So, I solved my problem. Yes, the good old command line. I use "atprogram" and the "External Tools" feature of AS6. Works smart and fast. And it could be much smarter if there are some more argument variables like $(ProjectDevice), and if $(ProjectFileName) without name extention. But I know, I cann't have all ;-)
regards,
Thomas
tom_schaefer wrote:
Hi all!
regards,
Thomas
Feel free to raise a bug for improvements that could be valuable to others aswell here: http://asf.atmel.com/bugzilla
MannImMond wrote:
tom_schaefer wrote:
Hi all!
regards,
Thomas
There are already bugs on this, http://asf.atmel.com/bugzilla/sh... , and the studio teams are aware of this...
:: Morten
