Program AVR with other AVR
10 posts / 0 new
Hello all;
first things first, this is my first post and I want to say a big THANK YOU for everything I have learned here.
I'm starting with AVR development and it's been an interesting field so far; I bought a SOC-Robotics IMU6410 board, which provides 9-DOF sensor (accelerometers, gyroscopes, magnetometers) all governed by an Atmel ATmega1284P. Nice toy to play with.
I also have a second IMU6410 board, which was sent to me by mistake; according to them, it seems to be a "test unit". While the "consumer" board comes with a preloaded STK500v2-compatible bootloader, this test unit seems to come with an empty flash; at least it doesn't seem to respond to the AVRDude commands.
I wonder whether is possible to use my first (proper) board to program the second (test) one or not. The board design includes ISP programming port, with {VDD, MOSI, MISO, SCK, SS, RESET, GND} pins.
What I have in mind is:
- Connect somehow these pins between both boards.
- Load a "software programmer" and a sample test .hex into the working board.
- Try to load the .hex into the non-working board (I would control its operation through a PuTTY session).
But I'm in need for at least some initial guidance. I don't even know if it's safe to connect ISP ports pin-to-pin with just a cable; any comment or help would be much appreciated.
PD: Yes, I know a hardware programmer would be faster and easier but a) the only shop around here is closed for the whole weekend now and b) I just want to learn a bit more :-)
Yes. You can use one AVR to program another AVR. However I would not recommend this as your first project.
There are many programmer software projects. A typical example is ArduinoISP sketch that comes with every Arduino board.
Well, I don't want it to be a programming project: I wouldn't have a problem in modifying a bit of other projects but not creating a new one by myself... when I said "software programmer" I meant a possibly already existing one :-)
I'll have a look to the ArduinoISP firmware and the original mega-isp project, thanks
Many (most?) AVR programmers feature an AVR on board. Apart from the Arduino sketch mentioned, all Atmels own programmers have an AVR on-board AFAIK. Also see e.g. USBASP.
Your main problem is to get the very first AVR programmed (the one to become a programmer). Unless you get an AVR with a bootloader pre-programmed, you will need a programmer to program the first AVR.
Do yourself a BIG favour. BUY a decent programmer. Atmels AVRISP mk II. Atmels AVR Dragon. An USBASP. Or an Arduino, that you load with the sketch mentioned.
Spending time building your own programmer WILL become a project of it's own, regardless of how much you try to avoid it. Spend a little money to get a lot of time doing what you really set out to do with AVRs.
An USBASP.
Which are about $3 on ebay (though be ready to be patient I ordered one and it took about a month to be delivered!)
I was amazed, mine came in a week. Yours must have come in a "slow boat". :)
I thought they where "to China", not "from". :D
It took 6 weeks for my usbasp's to arrive :shock: But I don't complain, they cost next to nothing and no extra for delivery.
Sometimes China Mail takes 10 days to England. Last week, a package took 23 days. I can live with both. After all, the price is cheap.
Larry might have VIP status. Less than 7 days to the U.S. seems exceptionally fast.
Well I have studied how difficult could it be to convert my specific board into a working USBasp-like programmer, and well, for the price of it I prefer buying one for myself :)
Thank you for your replies, now I'll look for some other topic to mess with :)
