IAR workbench ATmega16 : part of code optimization issue
15 posts / 0 new
I want to use medium optimization for rest of code; but there is a function where i dont want any optimization. How can i do it?
AVR Rocks but can be Bricked too smiley
Ask IAR.
Normally you set optimisation for the whole project.
You should be able to set different optimisation for individual files by right-click on the fileN.c
Otherwise you can use #pragma optimize
Shirley you can just use Help->Search "optimize"
Who's that girl? :lol:
"Shirly????" dont be dumb. you can just use my name instead of these @&*%^@*&^@% words....
OLD:
The problem is that when i use
__delay_cycles(F_CPU);
with optimization then i dont get 1 sec delay. i dont want to use timer bcz it is being used for other purpose like capture of event/gating.
so i want to disable optimization for this line.
 is updated to ::
even if I use optimization  __delay_cycles(F_CPU);
gives exactly what expected.
Problem Solved.
I didnt got 1sec because of my mistake.
:lol::lol::lol::lol::lol::lol::lol:
Shirley is a popular woman's name, nothing bad so far. Seems like some Brits are [ab]using it instead of "surely" :lol:
Certain references get lost in the translation. The word 'shirley' sounds similar to 'surely'. It was used in a pigdog western imperialist movie called 'flying high'.
'bcz' that's a new one. Your neighbours like to use 'cuz'. Why can't we just use the word 'because'?
nice one :)
I was not a translation. It was just my Russian guess bekoz ay du not nou Inglish at oll :lol:
You should get the correct number of wasted cycles regardless of your optimisation settings.
Simply examine the code in C-SPY. You should be able to count the cycles / time exactly when you Simulate.
Sorry about my mis-spelled "surely". I don't think that you have ever revealed your name.
I think that I answered your question in a helpful way.
If you have a problem, please post the actual code.
David. (my name)
p.s. from IAR Help:
void __delay_cycles(unsigned long count);
So even if you are running an Xmega at 32MHz, you are comfortably within the maximum 4294967296.
Just because you have a free-running timer used for ICP doesn't mean you cannot have a "tick" at every overflow to use for internal timekeeping.
And apparently your alternative is to just have your AVR sit in one spot for an entire second?!? No servicing of USARTs; no events such as your capture/gating; no display update; no user button servicing.
I'd strongly suggest that you re-visit your program structure. Doesn't Mega16 have three timers?
Are you disabling interrupts ? ( which is actually a bad idea )
The delay function is simple counter loop.
~10% interrupt overhead means ~10% extended delay time.
__delay_cycles() is really meant for SHORT delays of maybe a few microseconds.
go with theusch's method. Overflow tick counter and a wait loop.
Mike Adams
ADI Development, Inc.
http://www.adidev.com
... When it has to actually work.
Just to clarify, Us brits use the above as a quick one liner as in the following example:
Q) "Surely you can manage that"
A) "Yes but dont call me Shirley"
:P Stephen
Codevisionavr & Avrstudio 4.18
Easyavr5A-Jtagicemk1
Call me Pedantic, But not after 9.
if Milk_Brilliant
else Codevision_Avrs==Better
Timers are used for other purpose concurrently.
Timer 0 & Timer 2 for Gating & Control.
Timer 1 for capture.
problem solved because i just solved it myself :)
