Problem with GCC code generation (WinAVR 2009)
8 posts / 0 new
Hi!
I use (with -O2 option) GCC from WinAVR 20090313 version 4.3.2.
		unsigned char *p;
		unsigned short pp;
		cli();
 34e:	f8 94       	cli
		p = RingPointer;
 350:	f2 01       	movw	r30, r4
		*p ++ = 0xFF;
 352:	d2 01       	movw	r26, r4
 354:	8f ef       	ldi	r24, 0xFF	; 255
 356:	8d 93       	st	X+, r24
		*p ++ = 0x04;
 358:	84 e0       	ldi	r24, 0x04	; 4
 35a:	81 83       	std	Z+1, r24	; 0x01
 35c:	fd 01       	movw	r30, r26
 35e:	31 96       	adiw	r30, 0x01	; 1
		*p ++ = from;
 360:	11 96       	adiw	r26, 0x01	; 1
 362:	2c 93       	st	X, r18
		*p ++ = to;
 364:	61 83       	std	Z+1, r22	; 0x01
 366:	32 96       	adiw	r30, 0x02	; 2
		pp = (unsigned short)p;
		if ( (pp >> 8) == ((RAM_END - 0x100) >> 8) ) p = ring_start;
		RingPointer = p;
 368:	2f 01       	movw	r4, r30
		sei();
 36a:	78 94       	sei
register unsigned char * RingPointer asm( "r4" );
unsigned char * volatile ring_start = (unsigned char*) RAM_START;
Where is
Does it work in new version of GCC? What with register variables in newer version of GCC?
Ilya
ps: This is work:
if ( (pp & 0xFF00) == ((RAM_END - 0x100) & 0xFF00) ) p = ring_start;
You haven't shown enough context - the code could easily have been moved to before or after the sequence you posted. Post more of the .lss and note that I'm going to edit your thread title.
Hi, clawson!
No, I checked it.
Ok.
	WaitForReply = 0;
 304:	10 92 04 01 	sts	0x0104, r1
 308:	08 95       	ret
[skiped]
		unsigned char *p;
		unsigned short pp;
		cli();
 34e:	f8 94       	cli
		p = RingPointer;
		*p ++ = 0xFF;
		*p ++ = 0x04;
		*p ++ = from;
		*p ++ = to;
		RingPointer = p;
		sei();
 36a:	78 94       	sei
 36c:	cb cf       	rjmp	.-106    	; 0x304
#define RAM_START	0x1100
#define RAM_END		(RAM_START + 0x7FFF)
void ProcTel( unsigned char from, unsigned char to, unsigned char fc );
If RAM_END redefine as 'RAM_START + 0x8000' then it work fine.
And this is work too:
#if defined(__ASSEMBLER__)
#else
#define RAM_START	0x1100u
#define RAM_END		(RAM_START + 0x7FFFu)
#endif
But I don't like double define same constants for asm and C...
Ok, no matter ;-)
Ilya
501-q wrote:
Where is
Make sure you don't compare unsigned against signed. Enable warnings and fix them.
Yes, you can use R2..R7 as global registers.
Compile every module with -ffixed2 -ffixed-3 ... including modules contributing to libraries or make otherwise sure that no module unintentionally uses one of your global regs.
Moreover, notice that GCC can optimize global registers: global registers cannot be volatile; volatile only applies to memory storage classes, not to register.
This can lead to problems if you share a global reg between different IRQ levels.
if ( (pp >> 8) == ((RAM_END - 0x100u) >> 8) ) p = ring_start;
With this:
Problem was with compare between signed and unsigned shorts. But I don't undestand GCC's logic in this case.
WBR, Ilya.
Hi, SprinterSB!
SprinterSB wrote:
501-q wrote:
Where is
Yes, there is warning in this line:
pb.c:143: warning: integer overflow in expression
But this warning exist in both cases: when it work and when it isn't work.
To fix this warning I have to double define same constants (but I don't like it):
#else
#endif
Ilya
Isn't RAMEND defined in avr/io.h?
I use RAM_END as end of external RAM. All of external ram I use as ring buffer (in this case).
(ring_start need too: I wait for some event and then save part of ring buffer, change ring_start and wait same event again).
Ilya
