Context Switch
8 posts / 0 new
I'm writing a context switch however when I change the optimisation level the required order of saving the registers changes.
Any advise on overcoming this.
Is there away to read the status register using assembly of the UC3 proessor instead of reading it of the stack?
#define AVR32_SR 0
mfsr  Rn, AVR32_SR  // move from system register
mtsr  AVR32_SR, Rn  // move to system register
thanks, I might try using a software interupt to save the registers but I'll make a note of your suggestion should that not work.
Thanks digitalDan.
Could you tell me the location of the PC and LR???
All of the system register numbers accessible with mfsr and mtsr are listed in table 2-7 of the AVR32 Architecture Manual.
You access the PC and LR with any instruction that you would use with any other register: mov, ld, st, etc. Note that touching the PC with any instruction will cause its value to change; it is the program counter after all. :)
Hello Dan, is there away of checking the optimisation level in the code?
At compile time? Maybe. At run time? I don't think so.
At compile time you can use the gcc macros __OPTIMIZE__ and __OPTIMIZE_SIZE__. The first one is defined when compiling with any optimisation mode (-O1, -O2, -O3 and -Os), while the second one is only defined when compiling with -Os.
I don’t think it’s possible to distinguish between -O1, -O2 and -O3 at compile time or run time.
