Slick CRC7 code
12 posts / 0 new
Does anyone have a slick CRC7 routine that is small, quick, and doesnt use a lookup table. Something along the lines of this CRC16 routine:
unsigned int
CRC16(unsigned char *data, unsigned int length)
	unsigned int crc = 0;
	while(length--)
		crc  = (unsigned char)(crc >> 8) | (crc << 8);
		crc ^= *data++;
		crc ^= (unsigned char)(crc & 0xff) >> 4;
		crc ^= (crc << 8) << 4;
		crc ^= ((crc & 0xff) << 4) << 1;
	return(crc);
I started to dig into the workings so I could use the same theory for CRC7, but thought it best not to reinvent the wheel if its out there already (the real reaon: I feel like I am in number theory again and my brain is melting). Maybe someone would share if they had it? I have 2 version that work but, one is a solution that has a lot of branching and one is a lookup. Simple, elegant, clean, you have to respect that (even if you dont understand it).
Vern
Here is a crc implementation for an SAE datastream:
unsigned char gen_crc(unsigned char *ptr, unsigned char count)
  unsigned char i, crc = 0xff;
  for (i = 0; i < count; i++)
    unsigned char mask, data = *ptr++;
    for (mask = 0x80; mask != 0; mask >>= 1)
      unsigned char poly = 0, adder = 0;
      if (data & mask)        /* case for new bit = 1 */
        poly = 0x1c;          /* define the polynomial */
        adder++;
      if (crc & 0x80)
        poly ^= 0x1d;
      crc <<= 1;
      crc += adder;
      crc ^= poly;
  return ~crc;
Dave Raymond
Terminology clarification: The 16 in "CRC16" means 16 bits. Are you looking for a 7 bit CRC algorithm? Or are you really trying to find a CRC8 algorithm?
This is usually a tradeoff. If you want quick, go with a lookup table at the cost of some size. If you want small go with a loop style algorithm at the cost of speed. Pick your priority.
Have you tried searching Google? These are pretty common routines.
Nope, I was talking about CRC7. They have been around a while now.
They are all loops no matter which way you go. That CRC16 routine is pretty fast. Faster than a couple lookup routines I have seen. But still about twice as many instructions per loop as a good lookup. I really meant quick as in easy and simple, for example the CRC16 code I provided.
snafles wrote:
I have 2 versions that work but, one is a solution that has a lot of branching and one is a lookup.
what is the polynomial associated with the crc you're trying to compute? x^7+x^3+1?
x^7+x^3+1
I guess that would be very important information, huh? Sorry about that.
Vern
well, assuming 7 bit characters this might work:
unsigned char crc, data;
crc ^= data;
crc = (crc & 0x78) ^ (crc << 4) ^ (crc >> 3);
crc = (crc & 0x70>>1) ^ (crc << 3) ^ (crc >> 4);
or, even this
crc ^= data;
crc = (crc>>3) ^ (crc<<4);
crc ^= (crc & 0xf ) <<3;
crc = (crc>>4) ^ (crc<<3);
crc ^= (crc & 0x7) <<3;
crc &=0x7f;
Thanks for the info gizmo, I will try them out after the holiday (4th of July in US).
Vern
Here is the C code that I use (or was going to use) for calculating the CRC7 byte for a MMC command message. The CRC7 Poly is 0x89. The unsigned short value (treg) contains the working CRC value (upper byte) and the working data byte (lower byte). After every 8 shifts, a new data byte is loaded into the lower byte of the 16 bit register. This was a little easier than having to deal with rotating the carry from the data byte into the CRC.
The function inputs are the address of the first data byte and the number of bytes in the buffer. The function returns the CRC7 value with the MMC stop bit appended.
It's a little hard to read because of the True Type fonts.
unsigned char MMC_CalcCRC7(unsigned char *address, unsigned char ByteCount)
unsigned short treg;
unsigned char BitCount;
* treg structure
* |15|14|13|12|11|10|09|08|07|06|05|04|03|02|01|00|
* | C| CRC | DATA |
treg = *address++ << 8;
for (; ByteCount != 0; ByteCount--)
treg |= *address++; // Merge data byte into lower byte of CRC-Data register
for (BitCount = 8; BitCount != 0; BitCount--)
if (treg & 0x8000)
treg ^= CRC7_Poly << 8; // if carry out of CRC, then EOR with Poly (0x89)
treg <<= 1; // Shift CRC-Data register left 1 bit
return (treg >> 8) | 0x01; // Add stop bit to CRC for MMC
Gahelton!
This can be avoided by using the Code tag when posting.
Lets see if this is easier to read than my previous post (using the code tag this time).
* treg structure
* | C| CRC | DATA |
if (treg & 0x8000)
return (treg >>  | 0x01; // Add stop bit to CRC for MMC
