Passing data from bootloader to main program
8 posts / 0 new
I have a UC3A based system:
Bootloader 0x80000000 - 0x80003FFF
Main program header 0x80004000 - 0x800041FF
Main program 0x80004200 - 0x8000xxxx
The header contains information about the main program including a CRC to verify integrity. Once the bootloader verifies the header it does a procedure call to 0x80004200. This of course starts the normal startup routines and such since the main program is linked to start at 0x80004200.
What I would like to do is pass the 16 bit bootloader version number to the main program. I figure the startup is going to clear out internal RAM so I didn't try that.
What I did try is to store it in the ABDAC data register in the bootloader and then load that in the main program, but it shows up as zero. Not sure what I'm doing wrong there.
What about all those unused system registers? Especially the "Implementation Defined" ones. Do those actually exist and could they be used for this purpose?
Thanks..
may be look at PM ?
"13.6.15 General Purpose Low-power register 0/1" for example ?
Thanks Maddy, that worked.
hai guys , i got a requirement that i need a bootloader that has to copy data from pc to 1st 1/2 (0-5ff) of the flash and when i burn a new program it should write at the next 1/2 (600- bfe)of the flash and startaddress should jump to that location at 600 and again when we write 1st 1/2 should over write and start address jump to 000 it should repeat . so could we write a bootload doing this or not yar. like i am stuck in the middle .
Thanks in advance for the reply in advance.
if any one got an idea or some helpful code please help me guys. :oops:
nagella, please don't cross post and please start your own thread when asking questions.
sorry i am new ok i started in new topic . thanks for rectifying me dude now see whether can you help.na
you started another 100 topics!! Please don't do this, I have created a thread for your question. Your posting is almost spam now. :?
certsoft can you please send you code to my mail . it may be helpfull for me.
