Atmega644 and Timer0 CTC, overflow interrupt not working?
4 posts / 0 new
It's getting late and I have probably done something wrong but I can't seem to figure out exactly what at the moment... :(
I have this code that should start the Timer0 in CTC mode and I guess it should run and go to interrupt?
ISR(TIMER0_OVF_vect)
	TLC59116_SetSingle(ARRAY0,14,0xFF);
and
OCR0A = 63;	//Clear timer when it reaches this value
TCCR0A &= (1<<WGM01);//Timer 0 Clear-Timer on Compare (CTC)
TCCR0B &= (1<<CS02);//Timer 0 prescaler = 256
TIMSK0 &= (1<<TOIE0);//Enable overflow interrupt for Timer0
						//Timer should clear ~10 times per second
sei();							//Enable global interrupts
I have tested the TLC function elsewhere so i KNOW it works, the mega never goes in to the interrupt it seems! Any help is appreciated!
I'm using atmel studio 6 btw
- Brian
No, not unless you change &= into |= and you use the correct interrupt.
Stefan Ernst
Your timer will never be overflowed because it's cleared at CTC event. So you have to use appropriate interrupt (on compare, if I remember correctly).
Thank you both! Of course it should have been | not &! I also changed the interrupt so now it works, thank you very much!
Here is the fixed code just for good measure:
ISR(TIMER0_COMPA_vect)
and
TCCR0A |= (1<<WGM01);//Timer 0 Clear-Timer on Compare (CTC)
TCCR0B |= (1<<CS02);//Timer 0 prescaler = 256
TIMSK0 |= (1<<OCIE0A);//Enable overflow interrupt for Timer0
- Brian
