I am trying to convert a project that compiles fine in AVR Studio 4 to AVR Studio 6. I am having an issue with some includes from what it looks like. For some reason a required include doesn't seem to be functioning.
I am getting the following build errors:
Error 10 expected '=', ',', ';', 'asm' or '__attribute__' before 'usb_user_serial_number' usb_specific_request.h Error 13 unknown type name 'bit' hid_task.c Error 3 unknown type name 'code' usb_specific_request.h 25
Obviously 'bit' and 'code' haven't been defined and its spitting out those errors. I have included a file that contains the def's for those types in "compiler.h".
Compiler.h:
/*H************************************************************************** * NAME: compiler.h *---------------------------------------------------------------------------- * Copyright (c) 2006 Atmel. *---------------------------------------------------------------------------- * RELEASE: at90usb128-demo-hidgen-std-2_0_0 * FILE_REV: 1.13.2.30 *---------------------------------------------------------------------------- * PURPOSE: * This file redefines dedicated IAR AVR * keywords in order to ensure that any source file can be processed by * these compilers. *****************************************************************************/ #ifndef _COMPILER_H_ #define _COMPILER_H_ /*_____ I N C L U D E S ____________________________________________________*/ /*_____ D E C L A R A T I O N S ____________________________________________*/ #define LITTLE_ENDIAN #ifndef ASM_INCLUDE // define ASM_INCLUDE in your a51 source code before include of .h file typedef float Float16; typedef unsigned char U8 ; typedef unsigned short U16; typedef unsigned long U32; typedef signed char S8 ; typedef signed short S16; typedef long S32; #if (defined __C51__) typedef bit Bool; // Shall be used with _MEM_TYPE_BIT_ to optimize the memory. #else typedef unsigned char Bool; #endif typedef U8 Status; typedef Bool Status_bool; #define PASS 0 #define FAIL 1 #if (defined __C51__) # define _MEM_TYPE_BIT_ bdata // Used for bit accesses # define _MEM_TYPE_FAST_ data # define _MEM_TYPE_MEDFAST_ idata # define _MEM_TYPE_MEDSLOW_ pdata # define _MEM_TYPE_SLOW_ xdata #else # define _MEM_TYPE_BIT_ # define _MEM_TYPE_FAST_ # define _MEM_TYPE_MEDFAST_ # define _MEM_TYPE_MEDSLOW_ # define _MEM_TYPE_SLOW_ #endif typedef unsigned char Uchar; typedef unsigned char Uint8; typedef unsigned int Uint16; typedef unsigned long int Uint32; typedef char Int8; typedef int Int16; typedef long int Int32; typedef unsigned char Byte; typedef unsigned int Word; typedef unsigned long int DWord; typedef union { Uint32 dw; // l changed in dw (double word) because l is used for signed long... Uint16 w[2]; Uint8 b[4]; } Union32; typedef union { Uint16 w; Uint8 b[2]; } Union16; #ifdef __IAR_SYSTEMS_ICC__ typedef char bit; typedef int p_uart_ptchar; typedef int r_uart_ptchar; #endif #ifdef __CODEVISIONAVR__ typedef char bit; typedef int p_uart_ptchar; typedef char r_uart_ptchar; #endif #if !defined(__IAR_SYSTEMS_ICC__) && !defined(___ICC__) typedef char p_uart_ptchar; typedef char r_uart_ptchar; #endif #endif /**********************************************************************************/ /* codevision COMPILER (__CODEVISIONAVR__) */ /**********************************************************************************/ #ifdef __ICC__ #define _ConstType_ lit #define _MemType_ #define _GenericType_ __generic #define code lit #define xdata #define idata #define data #endif /**********************************************************************************/ /* IAR COMPILER (__IAR_SYSTEMS_ICC__) */ /**********************************************************************************/ #ifdef __IAR_SYSTEMS_ICC__ #include "inavr.h" #define _ConstType_ __flash #define _MemType_ #define _GenericType_ __generic #define code __flash #define farcode __farflash #define xdata #define idata #define data #define At(x) @ x #define pdata #define bdata // Memory Type Location #ifndef _CONST_TYPE_ # define _CONST_TYPE_ code #endif #define Enable_interrupt() __enable_interrupt() #define Disable_interrupt() __disable_interrupt() #include#define SFR_W_EXT(a,b) SFR_W_R(b,a) #endif /* General purpose defines */ /*#define _ConstType_ __farflash #define _MemType_ #define _GenericType_ __generic #define code __farflash #define xdata #define idata #define data*/ /*_____ M A C R O S ________________________________________________________*/ /* little-big endian management */ #define INTEL_ALIGNMENT LITTLE_ENDIAN #define MOTOROLA_ALIGNMENT BIG_ENDIAN // U16/U32 endian handlers #ifdef LITTLE_ENDIAN // => 16bit: (LSB,MSB), 32bit: (LSW,MSW) or (LSB0,LSB1,LSB2,LSB3) or (MSB3,MSB2,MSB1,MSB0) # define MSB(u16) (((U8* )&u16)[1]) # define LSB(u16) (((U8* )&u16)[0]) # define MSW(u32) (((U16*)&u32)[1]) # define LSW(u32) (((U16*)&u32)[0]) # define MSB0(u32) (((U8* )&u32)[3]) # define MSB1(u32) (((U8* )&u32)[2]) # define MSB2(u32) (((U8* )&u32)[1]) # define MSB3(u32) (((U8* )&u32)[0]) # define LSB0(u32) MSB3(u32) # define LSB1(u32) MSB2(u32) # define LSB2(u32) MSB1(u32) # define LSB3(u32) MSB0(u32) #else // BIG_ENDIAN => 16bit: (MSB,LSB), 32bit: (MSW,LSW) or (LSB3,LSB2,LSB1,LSB0) or (MSB0,MSB1,MSB2,MSB3) # define MSB(u16) (((U8* )&u16)[0]) # define LSB(u16) (((U8* )&u16)[1]) # define MSW(u32) (((U16*)&u32)[0]) # define LSW(u32) (((U16*)&u32)[1]) # define MSB0(u32) (((U8* )&u32)[0]) # define MSB1(u32) (((U8* )&u32)[1]) # define MSB2(u32) (((U8* )&u32)[2]) # define MSB3(u32) (((U8* )&u32)[3]) # define LSB0(u32) MSB3(u32) # define LSB1(u32) MSB2(u32) # define LSB2(u32) MSB1(u32) # define LSB3(u32) MSB0(u32) #endif // Endian converters #define Le16(b) \ ( ((U16)( (b) & 0xFF) << 8) \ | ( ((U16)(b) & 0xFF00) >> 8) \ ) #define Le32(b) \ ( ((U32)( (b) & 0xFF) << 24) \ | ((U32)((U16)(b) & 0xFF00) << 8) \ | ( ((U32)(b) & 0xFF0000) >> 8) \ | ( ((U32)(b) & 0xFF000000) >> 24) \ ) // host to network conversion: used for Intel HEX format, TCP/IP, ... // Convert a 16-bit value from host-byte order to network-byte order // Standard Unix, POSIX 1003.1g (draft) #ifdef LITTLE_ENDIAN # define htons(a) Le16(a) #define ntohs(a) htons(a) # define htonl(a) Le32(a) #define ntohl(a) htonl(a) #else #define htons(a) (a) #define ntohs(a) (a) #define htonl(a) (a) #define ntohl(a) (a) #endif // Constants #define ENABLE 1 #define ENABLED 1 #define DISABLED 0 #define DISABLE 0 #define FALSE (0==1) #define TRUE (1==1) #define KO 0 #define OK 1 #define OFF 0 #define ON 1 #ifndef NULL #define NULL 0 #endif #ifndef ASM_INCLUDE // define ASM_INCLUDE in your a51 source code before include of .h file #define CLR 0 #define SET 1 #endif /* Bit and bytes manipulations */ #define LOW(U16) ((Uchar)U16) #define HIGH(U16) ((Uchar)(U16>>8)) #define TST_BIT_X(addrx,mask) (*addrx & mask) #define SET_BIT_X(addrx,mask) (*addrx = (*addrx | mask)) #define CLR_BIT_X(addrx,mask) (*addrx = (*addrx & ~mask)) #define OUT_X(addrx,value) (*addrx = value) #define IN_X(addrx) (*addrx) # define Max(a, b) ( (a)>(b) ? (a) : (b) ) // Take the max between a and b # define Min(a, b) ( (a)<(b) ? (a) : (b) ) // Take the min between a and b // Align on the upper value on a boundary // i.e. Upper(0, 4)= 4 // Upper(1, 4)= 4 // Upper(2, 4)= 4 // Upper(3, 4)= 4 // Upper(4, 4)= 8 // ../.. # define Upper(val, n) ( ((val)+(n)) & ~((n)-1) ) // Align up on a boundary // i.e. Align_up(0, 4)= 0 // Align_up(1, 4)= 4 // Align_up(2, 4)= 4 // Align_up(3, 4)= 4 // Align_up(4, 4)= 4 // ../.. # define Align_up(val, n) ( ((val)+(n)-1) & ~((n)-1) ) // Align down on a boundary // i.e. Align_down(0, 4)= 0 // Align_down(1, 4)= 0 // Align_down(2, 4)= 0 // Align_down(3, 4)= 0 // Align_down(4, 4)= 4 // ../.. # define Align_down(val, n) ( (val) & ~((n)-1) ) /*M************************************************************************** * NAME: Long_call *---------------------------------------------------------------------------- * PARAMS: * addr: address of the routine to call *---------------------------------------------------------------------------- * PURPOSE: * Call the routine at address addr: generate an Assembly LCALL addr opcode. *---------------------------------------------------------------------------- * EXAMPLE: * Long_call(0); // Software reset (if no IT used before) *---------------------------------------------------------------------------- * NOTE: * May be used as a long jump opcode in some special cases *****************************************************************************/ #define Long_call(addr) ((*(void (_ConstType_*)(void))(addr))()) /* {For Langdoc} */ /*********************************************************** SET_SFR_BIT macro parameters sfr_reg : defined value in include file for sfr register bit_pos : defined value B_XX in include file for particular bit of sfr register bit_val : CLR / SET ************************************************************/ #define SET_SFR_BIT(sfr_reg, bit_pos, bit_val) { sfr_reg &= ~(1<<(bit_pos)); sfr_reg |= ((bit_val)<<(bit_pos));} /*********************************************************** bit_is_clear macro parameters PORT : defined value in include file for sfr register POSITION : defined value in include file for particular bit of sfr register example : if (bit_is_clear(PORTB,PORTB3)) ... ************************************************************/ #define bit_is_clear(PORT,POSITION) ((PORT & (1<<POSITION)) == 0 ) /*********************************************************** bit_is_set macro parameters PORT : defined value in include file for sfr register POSITION : defined value in include file for particular bit of sfr register example : if (bit_is_set(PORTB,PORTB3)) ... ************************************************************/ #define bit_is_set(PORT,POSITION) ((PORT & (1<<POSITION)) != 0 ) #define TID_GUARD(proc) ((__TID__ & 0x7FF0) != ((90 << 8) | ((proc) << 4))) /******************************************************************************/ /* GCC COMPILER */ /******************************************************************************/ #ifdef AVRGCC #define _CONST_TYPE_ #define _ConstType_ __flash #define _MemType_ #define _GenericType_ __generic #define code PROGMEM #define xdata #define idata #define data #define At(x) @ x #define pdata #define bdata #define bit U8 #define bool U8 //#include #include #include #define Enable_interrupt() sei() #define Disable_interrupt() cli() #endif #endif /* _COMPILER_H_ */
You can see that bit and code are defined in the file. Why am I still getting these build errors? The compiler.h is included in other files in the project. So confused.
Here is the project in case anyone wants to open it. (150kb)
http://ieeebcit.org/triden_usb_f...
