what's the part called you look through at an old analog video camera (the part where you see the b/w picture of what you are going to record).
I'm trying to interface such a part with an AVR. With my DVM i figured out which pin is which signal. First i thought the signal would be a standard video signal (composite video, ntsc or pal). I've tried an PAL signal from an Mini-CMOS Camera but it was not working. Does anyone know which kind of signal is used here?
