In AS5 it was possible to have the Ascii representation of values in the watch window by adding ,c to the variable name.
In AS6 this not works. How do I do this???
Regards
Leif[/img]
Regards
Leif[/img]
Hi, this still works for me :
a 65 int{data}@0x10fa (FP+1) a,c 65 'A' int{data}@0x10fa (FP+1)
Can you give more details, screenshots, examples of what is not working ?
Tnx,
Dan
Ok, well I see that if the array is defined global I can see the ascii presentation, but a local declared array is not possible. Another issue is taht in some case I get watch windov value optimized away when enter ,c. Strange.
ellile[/img]
Define the variable as volatile and/or assign the variable to another variable so that the compiler sees the variable as used and does not optimize it away. You may have to do both.
