avr-gcc -Os removes exported arrays from PROGMEM!
5 posts / 0 new
I'm using AVR-GCC 4.7.0-1 from Arch Linux, if it matters.
When compiling with -Os (which is pretty much a must for most source code,) an exported data array declared as PROGMEM will be removed by the compiler!
Compare without -Os:
$ avr-gcc -mmcu=atmega328p -c foo.cpp -o foo.o && avr-objdump -s foo.o
foo.o:     file format elf32-avr
Contents of section .progmem.data:
 0000 666f6f00                             foo.
Contents of section .comment:
 0000 00474343 3a202847 4e552920 342e372e  .GCC: (GNU) 4.7.
 0010 3000                                 0.
to with -Os:
$ avr-gcc -Os -mmcu=atmega328p -c foo.cpp -o foo.o && avr-objdump -s foo.o
 0010 3000                                 0.
Here is foo.cpp:
#include
unsigned char const foo[4] PROGMEM = { 'f', 'o', 'o', 0 };
Must I add some magic GNU make hack to my makefiles to not pass -Os for these files? That's fairly cumbersome :-(
Is this a known bug? Is there a patch?
No.
No. There is an unused, local variable that is optimized away. If you never use the variable, you won't even notice it has gone.
It's not a bug, it's a feature called optimization.
> Is there a patch?
Yes, you can apply this patch:
diff --git a/foo.cpp b/foo.cpp
index 98654f3..d88ba66 100644
--- a/foo.cpp
+++ b/foo.cpp
@@ -1,3 +1,3 @@
 #include
-unsigned char const foo[4] PROGMEM = { 'f', 'o', 'o', 0 };
+extern unsigned char const foo[4] PROGMEM = { 'f', 'o', 'o', 0 };
That patch should also work:
index 98654f3..3e6669e 100644
--- a/foo.cpp
+++ b/foo.cpp
@@ -1,3 +1,4 @@
 #include
+extern unsigned char const foo[4] PROGMEM;
It is offtopic, but...
You can use string literals as initializer for fixed-width arrays.
unsigned char const foo[4] PROGMEM = "foo"; // trailing zero present in array, the same as initial statement
unsigned char const foo[3] PROGMEM = "foo"; // valid, identical to { 'f', 'o', 'o' }
unsigned char const foo[6] PROGMEM = "foo"; // valid, identical to { 'f', 'o', 'o', 0, 0, 0 }
unsigned char const foo[2] PROGMEM = "foo"; // warning: initializer-string for array of chars is too long
                                            // result identical to { 'f', 'o' }
wbr, ReAl
It is not local. According to the standard, it has "vague" linkage, which is the same as, say, inline expanded templates. Without the -Os option, it clearly has global scope, and the documentation for -Os does not say that it changes the semantics of the program.
Having the linkage success of a separately compiled program change based on the "-Os" setting is, in my opinion, not very useful. I think symbol use for externally visible symbols should be determined by the linker, not the compiler, and it certainly would be both useful and standards-conformant behavior to do so.
I'm sure you can come up with language lawyering to argue that the current behavior is language conformant -- and you can also come up with an argument that it isn't. I'm not going to enter into that discussion more than I did here, though. The work-around you suggest -- add "extern" to the definition -- fixes this behavior.
It is not local. According to the standard, it has "vague" linkage, ...
7.1.1 Storage Class Specifiers, Clause 6 wrote:
Objects declared const and not explicitly declared extern have internal linkage.
