useing the JTAGICE and ISP Programmer with AVRDude
18 posts / 0 new
Hi
I wanted to try to program my Mega16 using AVRDude with a cloned JTAGICE/ISP Programmer and my STK500 board.
My questions which settings do I use for programmer id?
c:\avrdude -p m16 -c ??
I purchased this JTAGICE/ISP programmer on ebay it works pretty good with AVRStudio. I'm following a tutorial on youtube and they are using AVRDude.
Don
So why would you want to mess around with command line stuff? :roll:
Because you miss out on the fun of making it go. :wink:
Don,
Can you provide a link to the tutorial?
You will probably need to install libusb-win32 filter software to use the JTAGICE with avrdude.
If you can post a link to your actual device, you can get a good answer.
If you are using a JTAGICE-1 clone, you use the same COM port as Studio4 does. i.e. it appears as a COM port.
avrdude -c jtag1 -P com5 -b 115200 -p ATmega16
Note that Studio 6 does not support the JTAGICE-1 but Studio 4 does. (and Rowley, IAR, ... )
Well I'll look around to see if I can find where I got it. I'm using AVRStudio 4.18 still. My pc for micro-controllers is still running windows 2000 so I'm not sure if AVRStudio would work in it. The simple code I compiled with note pad II and WinAvr compiles fine. But When I put the same code in AVRStudio is gave me warning about using delay.h library I was using _delay_ms(100) to blink a led on PORTB pin 0. Dave I'll give that a try after dinner. And I'll search for the seller of my programmer.
Don
Did you set up the clock in the project settings?
This is the item I have here.
http://www.ebay.com/itm/AVR-JTAG...
John (js) is running Windows 2000 and I think AS 4.18 too, so that should not be a problem.
John is running XP pro, another Aussie is running Windows 2000 :) AS4.18 is correct, don't need the pain of anything else at the moment.
edit beware that AS5/6 will NOT support your programmer by the looks if things at the moment. AS4 will still be ok
DIY Version, Compatible with original JTAGICE 1
MODEL: AVRISP + JTAGICE
As there maybe many thousands of JTAG Mk1 around I suspect that AS4 will still be used well past my nursing home time. :?
Sorry, I confused you with Ross (valusoft). It's the meds. :wink:
avrdude -c jtag1 -P com4 -b 115200 -p m16
This command line worked great with AVRDude. After reading and understanding the warnings AVRStudio was displaying I was able to compile the same code in AVRStudio I didn't have the F_CPU set and I had to turn off optimization so utils/delay.h library could work correctly. So that is great makes me pretty happy. This is the tutorial I'm following along with http://youtu.be/JMMamSVy1Zs
Thanks everyone
Don
I sure hope you mistyped that and meant "on" not "off"! delay.h only works correctly when optimization is ENABLED.
Sorry I did mean optimization "on". Is there a certain one I should use? 1,2, or 3? Just wondering about the differ levels.
Don
If you don't have any specific reason to do otherwise, set optimization to -Os .
John
Thanks for the reply. I love those glasses and the look on your face. I often have days like that and have thought of your aviator over the years.
Don
Hey don't mix up the ugly dude (Johan) with the good looking dude (John) :lol:
Johan is not ugly! haha Too funny John!
