Problem in accessing Memory Card through MicroSD Adapter
19 posts / 0 new
Myself Sumanta Kumar Show is facing a problem
regarding accessing a Memory card within MICROSD
Adapter in a MICROSD Atmega32 Data-Logger. Please find
the circuit in the Attachment where it is used. I have
made all the connections according to the circuit
diagram. Can you please give suggestions about how this
problem can be solved.
Hi
exactly what is your problem ?, programming the mcu or reading/writing to the micro sd.
stephen
Codevisionavr & Avrstudio 4.18
Easyavr5A-Jtagicemk1
Call me Pedantic, But not after 9.
if Milk_Brilliant
else Codevision_Avrs==Better
The problem is occurring in identifying the memory
card in HYPERTERMINAL software. The HEX file is
properly burned into the microcontroller. But when I am
powering it on according to the circuit with push
button being pressed hyperterminal should detect a
memory card. But that is not getting accessed. Instead
of that the RED LED is blinking indicating that there
is error in accessing the card. I am trying to find but
yet not found out the cause of the problem as the
connection are all ok. Please check it and suggest if
anything can be done to solve the problem.
Sumanta
I read this note on the eXtreme electronics site about their microSD data logger....
NOTE: This product is for advanced users only. As this board does not has much of magic (its just electrical no software) we cannot help the users in anyway during their experiment.
NOTE: 16GB MicroSD Card shown in the image is NOT included.
But there WAS a link there too.
Actually I am using 4GB memory card and have fixed
in the Bredboard through wires instead of using MICROSD
Module connector. Can u tell me how the settings of
baud rate in Avr studio4 can be done for ATNEGA32 so
that can be in synchronous with the Baud rate settings
in Hyperterminal for the memory card to be detected by
the Hyperterminal software. Waiting for your
suggestions.
Sumanta
Please stick to ONE thread, I have deleted the others on the same subject.
yes surely. Can you be able to give some suggestions regarding solving the problem that I have posted.
Sumanta
Don't really understand your questions regarding baudrate.
Here's a couple of documents and a link that might help you to understand how SD cards work.
http://elm-chan.org/docs/mmc/mmc...
You are using the eXtreme electronics sd card module I assume? It has the spi pins in a connector so you can plug it into an avr board I suppose. If the avr board has an RS232 connector, you can talk to the AVR board using hyperterminal, but you need a big fat file system program to talk to the sd card module. Am I describing your setup correctly?
I am using extreme electronics burner to burn the
program into the microcontroller. I have not used the
MICROSD module connector, but instead of that I have
soldered pins on the adapter and fixed it in the
Bredboard. Then its connections are done according as
shown in the figure. Can you please help me to sort out
the problem. Hoping to get your response.
Sumanta
Are there any driver file required to be installed
so that the microcontroller is able to detect the
memory card and able to display it in the HYPERTERMINAL
software through RS232 port connection.
Sumanta
Which microcontroller board do you have? Does it have an RS232 connection? This board is separate from the eXtreme electronics sd card board, correct? Which AVR does it use?
Actually I am using ATmega microcontroller chip. It is connected to a MAX232 drivers/receivers chip which has an RS232 connection interfacing with the PC. The memory card through Adapter is connected with the microcontroller.You are right that the extreme electronics SD card board is separate which is only used for burning the program into the microcontroller. Please check the circuit diagram in my first post.
Currently I am using AVR STUDIO4 as the prgramming software. Can u give some idea how to write programs for drivers so that microcontroller may detect the memory card. Please have your suggestions regarding solving the problem.
Sumanta
You need source code for a 'fat file system'. There is one on the elm-chan site. It is probably compiler specific. Are you using the gcc compiler or the codevision compiler? I thnk cv has a file system module in their latest release. I thought the extreme electronics sd card module had to be connected using the spi pins to the avr. Now you say this is only connected during flash programming. I can assure you that it will be impossible to read the sd card if it is not connected to the avr.
Of course but for WHAT?
RS232? Does this work OK?
Or the SD card? https://www.avrfreaks.net/index.p...
I don't think anyone is understanding your questions here, sorry.
http://elm-chan.org/fsw/ff/00index_e.html
I have not used the
There is no SD-card in that circuit, only a connector marked "SD card module" with the necessary SPI signals connected + another pin connected that you don't need for talking to SD card.
What have me really worried is that you also have +5V wired to same connector. SD cards need 3.3V to be happy.
This also goes for all outputs in SPI interface (SCK, MOSI and CS). You need level translators for all those signals before they are connected to SD card.
Are you doing this level translation on the breadboard?
We cannot know if you have made SPI connections correct by looking only at the connector.
If you have sent 5V to the card there is a good chance that you've destroyed it.
Seems to me that the circuit drawing is not made by you, is that correct?
Does it belong to a ready made board or a kit you've bought?
If so, is there also a ready made program to go with it that now run on your mega32?
With proved code that handle transfers between card and mega32?
With FAT file system on it to handle files?
If the answer is yes to most of the questions my guess is that your SD card is broken because you sent 5v to it.
elm-chan as suggested by both me and Cliff have a lot of info on how to connect to a card and how to initialize them.
I have checked with the existing memory card in
card reader and it appears that the card has damaged.
Till I replace the memory card is there any
alternative way that I can run the MICROSD ATMEGA32
DATALOGGER circuit as I have the interfacing
connections of ATMEGA32 with MAX232 to the computer
through RS232 port.
Sumanta
connections in RS232 port
If you're familiar with the program inside mega32 you can change the code to simulate card data and send that to MAX232.
