bootloader, problems after reset...
2 posts / 0 new
I have written a custom bootloader (PC app + firmware) to update my Atmega128. The program seems to write data to the flash fine and the application code seems to be running.
(e.g., it will start flashing the correct LEDs, sending back some data over the USART, etc...)
My problem is that after the bootloader reset the device to addres 0x0000 and the app code starts running, anything involving interrupts behaves irregularly! I have a button connected to INT1, and when the isr for that pin is triggered, it seems to run fine the first time, but never again!
My interrupt driven USART routines also behave strange. Anything stream over 4 bytes seems to cause problems, and data gets replaced with the values "0xA0 0x00 0x00....."
Below I have posted my bootloader code. If anyone can find problems with it please respond ASAP! I am very desperate to solve this problem...
Note: I am using byte BOOTLOAD_FLAG_ADDR of the EEPROM as a flag to tell the bootloader whether or not to enter bootloader mode or run the application. The bootloader is being called upon reset (eg. reset vector fuse is programmed) *and* is also being run from the application (using a "jmp 0x1E000" instruction) . The flag is cleared at the end of the bootload process and is used to determine whether or not a successful bootload occured, or if the bootloader somehow crashed. (Trust me, it needs to be done this way for functionality reasons...)
void run_app()
	RAMPZ = 0;
	MCUCR = 0x01;	   	 	// Enable interrupt vector select
	MCUCR = 0x00;	   	 	// Move interrupt vector to flash
	asm("jmp 0x0000");  	// Run application code
void uart_init()
	UCSR0B = 0x00;
	UCSR0A = 0x00;
	UCSR0C = (1 << UCSZ0) | (1 << UCSZ1); /* 8,N,1 */
	// initialize USARTs
	UBRR0H = (unsigned char)(_UBRR >> 8);
	UBRR0L = (unsigned char)(_UBRR);
	/* enable transmit and recieve */
	UCSR0B = (1 << RXEN) | (1 << TXEN);
int uart_putchar(char ch)
	// Wait for empty transmit buffer
	while ( !(UCSR0A & (1 << UDRE)) );
	// Start transmittion
	UDR0 = ch;
	return 0;
int uart_getchar(void)
	// Wait for incoming data
	while ( !(UCSR0A & (1<<RXC)) );
	// Return the data
	return UDR0;
int start()
	if (bit_is_set(UCSR0A, RXC))
		return (UDR0 == BOOT_ACK);
	return 0;
int enter()
	unsigned int cfg_block;
	// read bootloader flag byte in eeprom
	eeprom_busy_wait();
	cfg_block = eeprom_read_byte((uint8_t*)BOOTLOAD_FLAG_ADDR);	// read cfg block from EEPROM
	return (cfg_block == 0x00) ? 0 : 1;
void clear_flag()
	// clear bootloader flag byte in eeprom
	eeprom_busy_wait();
	eeprom_write_byte((uint8_t*)BOOTLOAD_FLAG_ADDR, 0x00);
void delay()
	unsigned int i;
	for(i = 0; i < 2; i++)
		_delay_loop_2(0x0FFF);
void init()
	cli();								// disable interrupts
	boot_spm_interrupt_disable();
	DDRA = 0xFC;						// ooooooii: RFID_DATA_OUT, M_ERR
	DDRB = 0xFF;						// oooooooo
	DDRC = 0xFF;						// oooooooo
	DDRD = 0xFC;						// ooooooii: INT0, INT1,
	DDRE = 0xFE;						// oooooooi: RX0
	DDRF = 0xFF;						// oooooooo
	PORTA 		= (1 << PINA2);		// keep power on
	RAMPZ = 0;
 * main --
int main()
	unsigned char data[SPM_PAGESIZE];
	unsigned char local_checksum 	= 0;
	unsigned char remote_checksum 	= 0;
	unsigned int addr 				= 0;
	unsigned char addr_lo			= 0;
	unsigned char addr_hi			= 0;
	unsigned int i 				= 0;
	int done 						= 0;
	int err							= 0;
	init();
	if( enter() )
		uart_init();
		while( !start() )
			delay();
			uart_putchar(BOOT_NOTIFY);	// notify host of bootloader
		uart_putchar(OK);				// tell host to start sending Addresses
		done = 0;
		while(!done)
			// get page address
			addr_hi  	= uart_getchar();
			addr_lo 	= uart_getchar();
			addr = (addr_hi << 8) | (addr_lo);
			if(addr == 0xFFFF)
				done = 1;
				// init checksum
				local_checksum = 0;
				local_checksum ^= addr_hi;
				local_checksum ^= addr_lo;
				// get data bytes
				for(i = 0; i < SPM_PAGESIZE; i++)
					data[i] = uart_getchar();
					local_checksum ^= (unsigned int)data[i];
				remote_checksum = uart_getchar();
				if(local_checksum == remote_checksum)
					boot_page_erase(addr);						// erase page
					while(boot_rww_busy())
						boot_rww_enable();
					for(i = 0; i < SPM_PAGESIZE; i += 2)
						boot_page_fill((addr + i), (data[i]) + (data[i+1] << 8) );
					// Write page.
					boot_page_write(addr);
						boot_rww_enable();
					// verify data
					err = 0;
					for(i = 0; (i < SPM_PAGESIZE) && !err; i++)
						if( data[i] != pgm_read_byte((addr + i)) )
							err = 1;
					if(err)
						uart_putchar(VERIFY_FAILED);
						uart_putchar(OK);
					uart_putchar(CHECKSUM_FAILED);
					err = 1;
	if(!err)
		clear_flag();
	run_app();
	return 1;
void run_app()
	RAMPZ = 0;
This could be the issue. When you call this function, you jump to your code, but the processor IO could be in an unknown state.
The better way to do a "soft reset" is to enable the watchdog timer (at a low interval) and then go into an infinite loop. This allows the watchdog to perform a processor reset, which then puts the IO into a known default state. You can even wrap this up in a macro and put it into a header file:
#include
#define soft_reset()  \
{  wdt_enable(WDTO_15MS); \
    for(;;); \
void run_app()
	RAMPZ = 0;
	soft_reset();  	       // Run application code
Let us know if this solves the problem.
BTW, thanks for formatting your code with Code button. And your code is very easy to read! :)
