Really weird counter glitch
6 posts / 0 new
Hallo all.
I am having a lot of trouble with timer/counter 0\
I have configured it as a counter:
 .include "m328Pdef.inc"
 .def temp = R16
  .org 0x0000
 maint:
	ldi temp, high(ramend)
	out sph, temp
	ldi temp, low(ramend)
	out spl, temp
port_setup:
	ldi temp, 0x00
	out DDRD, temp
	ldi temp, 0x0F
	out DDRB, temp
RPM_Calc2:
	clr R27
	clr R28
	ldi Temp, 0x06
	out TCCR0B, Temp
	rcall delay_short
	ldi Temp, 0
	out TCCR0B, Temp
problem:
	ldi Temp, TCNT0
	out TCNT0, Temp
	out PortB, Temp
here:rjmp RPM_Calc2
delay:
	nop
	nop
	ret
delay_short:
	push R21
	ldi R21, 200
DQ:	call delay
	dec R21
	brne DQ
	pop R21
	ret
Now when I run this code in AVR studio 5 I get the value of 38 loaded into "Temp" at the label "problem".
I have no idea what is causing this and it is causing havoc with my larger code.
Please help
You're actually loading the SRAM address for TCNT0 into Temp doing this
problem:
   ldi Temp, TCNT0
Don't know what number you intend to load into Temp, but probably not SRAM address.
He probably meant
lds Temp, TCNT0
except that would not work either as TCNT0 is almost certainly defined as an IO not RAM address and should be read with:
in Temp, TCNT0
If that was the intention it does make you wonder what the purpose of:
   in Temp, TCNT0
   out TCNT0, Temp
   out PortB, Temp
might be - why would one read it then immediately write it back?
Btw, writing comments is an essential part of writing code.
As it look now, no one else but you have a clue what you really want to happen in that code line.
   in Temp, TCNT0
   out TCNT0, Temp
   out PortB, Temp
maybe should be
   in Temp, TCNT0
   out PortB, Temp
Which would load the value of TCNT0 on PortB.
Thank you everyone so much... Its so simple I can't believe I missed it!
