full duplex comunication with rs485
9 posts / 0 new
I want to make a communication MASTER (atmega2560) - SLAVE (ATMEGA32) using RS485 full duplex.
I want the MASTER to send a data of 8 bytes, on the SLAVE , i need use bascom-avr
Can anyone help me with some sample code ?
Thanks in advance.
If you are using 2 chips only and full duplex then there is NO DIFFERENCE to RS232, so use the standard BASCOM com stuff.
Just get it to work with RS232, then get a couple of those RS232 to RS485 port powered dongles from B&B electronics.
Why? There is only 2 AVRs involved :)
You can't do full duplex with RS-485
True, so we need to invent another name like 4 wire RS485 (or even RS422??) :)
So 1 x RS485 link going master to slave with TX permanently on in the master and RX permanently on in the slave.
Another 1 x RS485 link going slave to master with TX permanently on in the slave and RX permanently on in the master.
We now have a "Clayton" RS485 link where you have RS485 when you really don't. So confusing.. :wink:
The advantage over RS232 is that the above set up can go up to 4000ft or about 1.3Km instead of the usual 15m or so for RS232.
Why? Wikipedia disagree.
http://en.wikipedia.org/wiki/Rs485
I was thinking this could be done. Why can it not be done?
If using a four conductor cable (w/ GND of course) and the proper RS-485 chips.
I have not done that, but looking at some documents (Jan Axelson) discusses this at length in her book "Serial Port Complete Second Edition".
I'll believe corporations
are people when Texas executes one.
From that Wiki page
EIA-485, like EIA-422 can be made full-duplex by using four wires
Of course RS485 can be full duplex.
_______
Rob
Scattered showers my arse -- Noah, 2348BC.
Rob Gray, old fart, nature photographer, embedded hardware/software designer, and serial motorhome builder, www.robgray.com
