compare two registers in assembly
7 posts / 0 new
Hi guys,
I am using assembly.
I want to compare two registers, one being twice the value it is currently (multiplied by two) without changing any of the values of either register.
i.e.
cp ZL,(XL*2)
breq....
is it possible without changing the value of XL even temporarily?
No, you need to take a copy and double that then use in the compare.
yes that is what I was afraid of, thanks.
If you don't want to do the double (LSL = ADD RnRn) at this point perhaps you can keep a "shadow" of XL and add 2 to that each time you increment XL? This moves the "overhead" to another place in the code which *might* help.
here is what I did, it works.
	lds	R10,TempH		;load high byte from ram
	mov	R7,R10
	lsl	R7			;multipy by two
	lds	r11,TempL		;load low byte from ram
	mov	R8,r11
	lsl	R8			;multipy by two
the compare happens later down the road. There may be a more efficient way to do this, but it works for me. Thanks clawson for your quick response!
This way you are comparing BOTH values multiplied by 2 - why not then just compare the original values instead?
Maybe he's comparing 16 bit values, and he isn't doing a carry between the high and low bytes?
