I'm having a problem where my serial output is no longer accurate after a power cycle. When I first program my board (with a Dragon), everything works fine. However, performing a reset by cycling power causes all output to be garbage. I'm using a 12MHz crystal oscillator with the specified capacitors.
Has anyone experienced an issue like this before? Do I need to set fuses? I don't see anything in the fuse editor that looks like it would help.
EDIT: Through further testing, I found that after programming I could get a clean waveform when I toggle a GPIO pin; after a power cycle, the waveform varies like crazy. What could cause this?
