ahhh ok, after a few trials, basically when Es_month is 4 digits, the response has the 1st byte of Etot corrupted.
For ex:
Etot = 12657;
Es_month = 345;
Ew_month = 789;
12657345789
ok. If
Etot = 12657;
Es_month = 3456;
Ew_month = 789;
26573456789
WRONG. 1's byte corrupted. Should be 12657.
Etot = 12657;
Es_month = 345;
Ew_month = 7896;
126573457896
ok.
Etot = 1265;
Es_month = 3456;
Ew_month = 789;
2653456789
wrong.
Etot = 1265;
Es_month = 34;
Ew_month = 789;
126534789
ok...
Dean mentioned:
Remember that in C a zero byte is treated as a null-terminator -- if you have junk data in the first 10 bytes of the string, chances are one might be a terminator which will stop any display of the buffer contents before the contents of the EEPROM read string is reached.
and again a few comments later
You need to read/write one more byte to EEPROM than there are characters in the string -- there's a hidden 0x00 byte at the end of each string which terminates it. Without the terminator, your string routines will become confused.
Maybe this could be the problem? I can't find why the 1st byte is getting corrupted when Es_month is a 4 digit number :/
These are surely far too small? A string defined as [5] can hold 4 digits and the terminating 0x00. A string defined as [4] can hold just 3 digits and the 0x00. If you try to put a four digit string into [4] it will write over the start of the next string in mmeory.
Personally I always work out the worst case> For example largest itoa() is going to be 5 digits, possibly with sign so 6 characters, then you need room for the 0x00. So 7 characters. To be safe I'd blow the memory budget and just make it [8] or if I was feeling particularly flaithiúl I'd actually make it [10] to be aboslutely positive. Start cutting the [10]s back to [8]s when you thing RAM is getting low. (and test the worst case strings)
Posted by A-RapESTONIA: Sun. Feb 20, 2011 - 07:07 PM
1
2
3
4
5
Do somebody know if i could somehow monitor (make readable) my internal EEPROM to the device outside. For example: I have TI PGA309 signal conditioner which requires external EEPROM to read config data. It uses I2C aka TWI for reading. Can i somehow make my Atmega 324 memory readable by PGA309 via TWI?
Thanks!
Estonia, Otepää is the place where you can find me...
Posted by A-RapESTONIA: Sun. Feb 20, 2011 - 09:53 PM
1
2
3
4
5
So practically it means mechanically write all the functions: 1)set avr in slave read mode
2)make functions which emulate the prodecure when PGA asks memory location this n that answer with a memory location from AVR eeprom?
Okay then.
It would be simpler to program PGA through UART then...
I just thought maybe there is some shortcut how to do this.
I am somewhat new to programming micro controllers, so please excuse me if this is a dumb question...
In my program, I declare several "variables" with the EEMEM attribute. At the beginning of the program, I read the values in (garbage if the EEP file was not downloaded). The user of the program has the capability of changing the values stored in the EEPROM. Scenario: a user sets all of the EEPROM variables to valid values. The board is then turned off. When it is turned on again, the program re-initializes its SRAM equivalent variables from EEPROM. I understand all this (isn't that the point of EEPROM?). However, if I set the ESAVE fuse, make some changes to the program and recompile it, and re-download it to the chip, what does it matter if the EEPROM is overwritten or not? Won't the compiler have given different addresses to my EEMEM variables? How will the program know where the previously saved EEMEM variables are stored?
Posted by abcminiuser: Thu. Mar 3, 2011 - 03:37 PM
1
2
3
4
5
That's true, however if you place *all* your EEPROM variables into a single struct, as long as the compiler's packing and ordering rules are not changes between versions those variables should always map to the same place.
It's also useful for assembly programmers or manual EEPROM location management, sine in that case you always certain where everything is stored.
- Dean :twisted:
That makes sense. If I create a struct with a bunch of settings, I think I would always need to read/write the EEMEM variable to/from EEPROM in its entirety (i.e., couldn't do just one of the subvariables). Is this true?
At the moment, we now have access to the eeprom memory, via the routines now provided by eeprom.h. There are three main types of EEPROM access: byte, word and block. Each type has both a write and a read variant, for obvious reasons. The names of the routines exposed by our new headers are:
Well... I just tried writing some code using eeprom_write_block and my compiler gave me a warning so I checked and it looks like the order of my eeprom_write_block is back to the original "wrong" order. So which one is correct? :)
Looks like someone is changing things on us hehe.
I currently use the EEPROM to store some program configuration data (i.e. thresholds, durations, ...).
Now I want to adapt the program behaviour by patching some single EEPROM bytes. As far as I know AVR-Studio can only writw down complete EEPROM-files. Which tool can be used to do that? Wouldt be great if someone knows a simple command line tool.
Read the entire eeprom to a .hex - change one byte then write the whole thing back.
sir i am trying to do a line follower and i am not able to program it so pls help me with it
abcminiuser wrote:
Davef,
Damnit, yet another typo. That should indeed be read_word - I'll go fix that now. Amazing that anyone still bothers to read my tutorials with all these silly mistakes!
In , eeprom_read_byte and eeprom_write_byte use a u08 pointer for the address. Doesn't this mean you can only access 256 bytes in the EEPROM? What about the remaining 1024-256 = 968 EEPROM bytes in a ATmega32?
That tripped me up too at the start. In AVR-GCC, all pointers are an int in size, two bytes. The pointer typecast only specifies what type of data the pointer is pointing to, not the pointer's size. A (uint8_t*), (uint16_t*) and (uint32_t*) are all identical in size, they just point to increasingly larger datatypes.
For example, (uint8_t*)0x1234 is a pointer two bytes in size, pointing to a byte at the location 0x1234.
This is a problem when dealing with pointers to the AVR's flash memory, since in some AVRs this overflows an int. Because of this, pointers to flash addresses are still two bytes in size but the pointer is word rather than byte aligned, so an increase of one in the pointer's address corresponds to a jump of two bytes.
If I can think of enough material for this I might make it into a short tutorial since it seems to be such a prevalent issue.
Then kindly explain what on earth the post you quoted or this entire thread has to do with your question?!? This thread is about using EEPROM with the avr-gcc compiler.
Hello Everyone,
I have a very simple question. Would these eeprom instructions work for the avr atmega1284p microcontroller.The datasheet is below ,please kindly have a look as i am a newbie and understand very little of programming language
Posted by JohanEkdahl: Mon. Mar 5, 2012 - 07:34 PM
1
2
3
4
5
I have a very simple answer: Yes. :D
As of January 15, 2018, Site fix-up work has begun! Now do your part and report any bugs or deficiencies here.
No guarantees, but if we don't report problems they won't get much of a chance to be fixed! Details/discussions at link given just above.
EEMEM char ok_test[] = "Test Ok!\n\r";
EEMEM char copy_right[]="8-bit Test device super puper multi pulti, C 2012 Vr.SuperWriter";
void SendStr(char *string)
while (*string!='\0') /
SendByte(*string);
string++; /
void SendByte(char byte)
while(!(UCSRA & (1<<UDRE)));
UDR=byte;
USART_Init(51);
char *u;
string[]=""
u=string;
eeprom_read_block(u,ok_test,sizeof(ok_test));
SendStr(u);
eeprom_read_block(u,copy_right,sizeof(copy_right));
SendStr(u);
In terminal correct writing message Test Ok!
but next message endlessly repeated ((
Another said that if eeprom_read_block(u,copy_right,16) displays correctly the first 16 characters
Where did I go wrong?
u is a pointer but is only pointing at ONE BYTE of allocated storage?!? I'm not going to count all the characters in copy_right[] but maybe try something like:
USART_Init(51);
char u[50];
But why make a RAM copy anyway? Why not make SendStr() read direct from EEPROM? (if you might also have a SendStr() to read from RAM then add an E or something):
I'm a newbie. Other than the non-volatility, are there other reasons why you would use EEPROM instead of flash? Flash also stores data without power applied, corect?
Posted by abcminiuser: Wed. Apr 4, 2012 - 07:01 PM
1
2
3
4
5
Flash can only be written in pages (batches of 128 or so byte blocks) and can only be modified from the bootloader section of the chip. The EEPROM is byte addressable, and can be altered from anywhere. Special fuses in the newer chips allow the EEPROM contents to be preserved between application reprogrammings, while any custom flash data would be destroyed.
- Dean :twisted:
Posted by abcminiuser: Sat. Apr 7, 2012 - 01:15 PM
1
2
3
4
5
Always use the update function - it takes a few extra cycles (not very many at all) but will skip the writing of EEPROM cells that are already in the desired state. That means that you will generally save time overall if most of the bytes' values haven't changed, and it will save the lifespan of the EEPROM.
The write functions are provided for backwards compatibility and shouldn't be used in new applications.
- Dean :twisted:
Posted by JohanEkdahl: Sat. Apr 7, 2012 - 01:48 PM
1
2
3
4
5
now, i "should" or "must" use the update function instead The write functions for any application ?
There is no absolute truth re this, no one single dictated way to do things. Dean already explained the pros and cons of both set of functions. Let's try again:
The update set of functions execute slightly slower, but generally imposes less wear on the EEPROM.
The write set of functions execute slightly faster, but potentially wears down the EEPROM faster. When it is said about some function that it "should not be used in new applications" this often means that there is a plan to remove the function eventually.
With that information you are absolutely free to pick either the write or the update version of the functions, and then be prepared for the consequences of your choice:
If you have extremely tight demands on performance you might go for the write functions, but when they are possibly removed from avrlibc you will have to implement your own. If such tight demands are not present, you of-course go with the update versions because they impose less wear on EEPROM and they will most likely remain in avrlibc for the foreseeable future.
Posted by abcminiuser: Sat. Apr 7, 2012 - 04:14 PM
1
2
3
4
5
Note that the time required to read the EEPROM is very little, when compared to the time required to write to it - so if your data to write doesn't change much, you can actually save time overall with the update functions as well as preserve the EEPROM's lifespan. I'd say that using the write functions over the update functions would be something done 1% of the time, and as a general rule the update functions should always be used unless you absolutely know what you are doing.
- Dean :twisted:
Whatever I tried, there was nothing in .eep file.
I tried and Optimization -Os. I included eeprom.h header, and nothing.Defined EEVar as EEMEM.
I am new in all this, and I got assignment to program robot! :?
There is nothing in what you show that would create a .eep file??
You appear to be using eeprom_write_block(). (BTW that should be eeprom_update_block() these days). That is a run time function it does not create fixed .eep data at compile time.
Short of a crystal ball I don't know how it's possible to help you without seeing the code you are talking about. If I use the code I showed above I get:
Posted by natalijana: Wed. Apr 11, 2012 - 02:51 PM
1
2
3
4
5
Here is a code:
#include
long EEMEM Putanja1;
long EEVar;
long ReadLongFromEeprom(void)
long temp;
eeprom_read_block((void*)&temp, (const void*)&EEVar, sizeof(long));
return(temp);
int main()
do{ ADCSRA|=(1<<ADSC);//i use Sharp sensor for
//detectio, and this all works exept writing in //EEPROM
if (ADC>=500)
GetAbsPos(101,&Motor1AbsPos);//here i get
//value of counter
eeprom_update_block ((const void *)&Motor1AbsPos, (void *)&EEVar, sizeof(long));
MotorStop(101);
break;
}while(1);
while(1);
if (ADC>=500)
You aren't waiting for the conversion to complete? Make that:
while(ADCSRA & (1<<ADSC)); // wait while the bit remains high
if (ADC>=500)
Anyway on the EEPROM thing:
long EEVar;
long Motor1AbsPos;
long temp;
return(temp);
(a) nothing here would create a .eep file
(b) as nothing else is done to write to the EEPROM one has to assume it contains all 0xFF after a chip erase
(c) the read_block call is wrong. Why using _block_ when it's a 23bit "dword" you are reading anyway? eeprom_read_dword() would seem the more obvious call to read the 4 bytes of a "long". As written the call is:
OK, the destination is fine - temp is "long" and the 3rd parameter is passing sizeof(long) so this will be reading 4 bytes. However the source address for that read is wrong. You are using the address of EEVar yet this is a RAM based variable? Surely what you intended to read from here was "Putanja1" so its the address of that (which is an address in EEPROM as that variable is declared as EEMEM) that you should be passing.
If you want a .eep file and you want it to have an initial value then use something like:
long EEMEM Putanja1 = 12345678;
long Motor1AbsPos;
long temp;
eeprom_read_block((void*)&temp, (const void*)&Putanja1, sizeof(long));
return(temp);
When you build this program a .eep file will then be created. If you program that into the AVR's EEPROM when you also put the program code in then the eeprom_read_block will then read 12345678 back from the "Putanjal" location and store it into "temp". However as I say eeprom_read_dword() is a more obvious function so:
long Motor1AbsPos;
return eeprom_read_dword((void*)&Ptanjal);
Posted by natalijana: Wed. Apr 11, 2012 - 09:23 PM
1
2
3
4
5
I have a few more questions:
1.
I ran first part where I put some data in EEPROM, and loaded code into FLASH and EEPROM,than I comment that part and ran "Read" part. So, do I have to program again EEPROM, each time when I load code in FLASH? (Probably silly question, but i didn't work with EEPROM before)
2.
And, when I look hex. editor there is something like
:040000006400000098
:00000001FF
where "64" is initial EEMVE variable like Address, but what is this "98" ?
Posted by natalijana: Fri. Apr 13, 2012 - 05:11 PM
1
2
3
4
5
Again, I have a problem. I want to put 2 Arrays in EEPROM, and after to read them. I am certain that data are correct written into EEPRom (the .eep seys so because I defined Arrey[13] and in .eep found 4 lines with smth like arrey- the number I only used), but when I want to read them, there is a problem.
Did I correctly call "Read" function:
I also tried instead of ArrayEE with &ArrayEE, but nothing. I defined smthEE like EEMEM.
Also there is a chance that I wrote smth bad in "for" loop, if it's that case, please just tell me, so I can try to fix that. Here is a code:
Why read the whole array into RAM? Why not pick up the element you need one at a time? Anyway if you really want to read the whole array you do not want
sizeof ArrayEE[0]
That's only the size of a single element not the whole array.
Anyway here's a simple example reading the elements of an array one at a time:
Posted by abcminiuser: Fri. Apr 13, 2012 - 07:25 PM
1
2
3
4
5
I updated the tutorial PDF contents on my site the other day to reflect the API changes made to the EEPROM library over the last few years. Download the PDF from here for the latest version:
Posted by natalijana: Sat. Apr 14, 2012 - 05:31 PM
1
2
3
4
5
I am sorry to bother you again, but it seems that I can't put an array in EEPROM, I've read Dean's tutorial and I think I understood how it works, but it won't to read/write in EEPROM. Is there something else I can do that not include program, some adjustments in maybe AVR Studio 4 or ISP communication?
Posted by JohanEkdahl: Sat. Apr 14, 2012 - 05:41 PM
1
2
3
4
5
You should produce a minimal but complete, clean building and runnable program that demonstrates the problems you describe. Ideally we're talking about perhaps 20 lines of code. Post that program here and we can help.
You are aware of that AVR Studio 4 has a checkbox for if the EEPROM contents should be preserved or ereased dirung flash programming?
I checked the Array and it form good values, but the problem is that it won't to put in EEPROM, I've been looking that code for days, but I couldn't find where I'm wrong?
thanks clawson, i saw several other comments to this tutorial with eeprom issues so i thought it'd be ok.
the tutorial quotes:
while eeprom.h void function is:
warnings corrected, and the output improved:
but the first byte is corrupted. it should be
any ideas? thank you!
Topahhh ok, after a few trials, basically when Es_month is 4 digits, the response has the 1st byte of Etot corrupted.
For ex:
ok. If
ok.
wrong.
ok...
Dean mentioned:
TopThese are surely far too small? A string defined as [5] can hold 4 digits and the terminating 0x00. A string defined as [4] can hold just 3 digits and the 0x00. If you try to put a four digit string into [4] it will write over the start of the next string in mmeory.
Topdidn't know that! Thank you very much! : )
- Eric
TopDo somebody know if i could somehow monitor (make readable) my internal EEPROM to the device outside. For example: I have TI PGA309 signal conditioner which requires external EEPROM to read config data. It uses I2C aka TWI for reading. Can i somehow make my Atmega 324 memory readable by PGA309 via TWI?
Thanks!
TopYou can simulate whatever kind of interface the PGA309 expects to use with a microcontroller such as an AVR so the answer is yes.
TopSo practically it means mechanically write all the functions: 1)set avr in slave read mode
Okay then.
TopQuestion regarding the EESAVE fuse:
Science is not consensus. Science is numbers.
TopThat's true, however if you place *all* your EEPROM variables into a single struct, as long as the compiler's packing and ordering rules are not changes between versions those variables should always map to the same place.
- Dean :twisted:
TopThat makes sense. If I create a struct with a bunch of settings, I think I would always need to read/write the EEMEM variable to/from EEPROM in its entirety (i.e., couldn't do just one of the subvariables). Is this true?
From Clawson's post on page 7:
If I wanted to read the data from memory into a RAM structure, would the code be:
P.S. Since I boorishly forgot to say it in my first post -- thanks for taking the time to put together such a good tutorial.
TopYes.
TopWell... I just tried writing some code using eeprom_write_block and my compiler gave me a warning so I checked and it looks like the order of my eeprom_write_block is back to the original "wrong" order. So which one is correct? :)
TopI currently use the EEPROM to store some program configuration data (i.e. thresholds, durations, ...).
TopRead the entire eeprom to a .hex - change one byte then write the whole thing back.
TopThanks so much for all your helpful tutorials mate.
They are much appreciated especially when you've left your Final Year project this late lol :)
Topsir i am trying to do a line follower and i am not able to program it so pls help me with it
TopThen kindly explain what on earth the post you quoted or this entire thread has to do with your question?!? This thread is about using EEPROM with the avr-gcc compiler.
TopI've read this thread and now know how to use EEMEM to have the compiler generate a .eep file to 'initialise' basic eeprom variable, and arrays.
I am using an 'overall structure' to hold all my eeprom variables.
I need to initialise an array of structures within the outer structure
So when I use
is it possible initialise the inner array of structures?
or is there a better way of doing this?
TopIf your C compiler supports C99 you can also use named initializers:
Cliff
TopThank you Cliff :) - it's obvious when you see it written down, but I just couldn't get my head round it.
Topthanks to info.
TopHello Everyone,
http://www.atmel.com/Images/8059...
Please kindly respond as soon as possible as i need to learn this programming and then write the code for my greenhouse project. Thank you
TopI have a very simple answer: Yes. :D
Tophelp me pls! for my bugs (
Topu is a pointer but is only pointing at ONE BYTE of allocated storage?!? I'm not going to count all the characters in copy_right[] but maybe try something like:
TopCompiler error:
Error 1 invalid conversion from 'char*' to 'const uint8_t*'
TopI'm a newbie. Other than the non-volatility, are there other reasons why you would use EEPROM instead of flash? Flash also stores data without power applied, corect?
TopFlash can only be written in pages (batches of 128 or so byte blocks) and can only be modified from the bootloader section of the chip. The EEPROM is byte addressable, and can be altered from anywhere. Special fuses in the newer chips allow the EEPROM contents to be preserved between application reprogrammings, while any custom flash data would be destroyed.
- Dean :twisted:
TopHI
i have a qustion!
when i use void eeprom_update_byte (uint8_t *__p, uint8_t __value); or like this function?
or when are these beter to use ?
and can i use e.g,
void eeprom_write_byte (uint8_t *__p, uint8_t __value);
insted
thanks
TopAlways use the update function - it takes a few extra cycles (not very many at all) but will skip the writing of EEPROM cells that are already in the desired state. That means that you will generally save time overall if most of the bytes' values haven't changed, and it will save the lifespan of the EEPROM.
- Dean :twisted:
Topthanks alot for rapid answer!
now, i "should" or "must" use the update function insted The write functions for any application ?
TopThere is no absolute truth re this, no one single dictated way to do things. Dean already explained the pros and cons of both set of functions. Let's try again:
Topthanks a lot.
TopNote that the time required to read the EEPROM is very little, when compared to the time required to write to it - so if your data to write doesn't change much, you can actually save time overall with the update functions as well as preserve the EEPROM's lifespan. I'd say that using the write functions over the update functions would be something done 1% of the time, and as a general rule the update functions should always be used unless you absolutely know what you are doing.
- Dean :twisted:
TopHello, I was trying in many ways to figure out where I was wrong, please, help. This is my code:
Thank you.
TopThere is nothing in what you show that would create a .eep file??
If you wrote something like
then either of those WOULD create .eep data.
TopI must correct myself. I defined EEVar like EEMEM, and I've gotten .eep but full with zeros. I have no write in EEPROM!
Thank you.
TopShort of a crystal ball I don't know how it's possible to help you without seeing the code you are talking about. If I use the code I showed above I get:
TopHere is a code:
TopYou aren't waiting for the conversion to complete? Make that:
will do what you require here.
TopI have a few more questions:
1.
2.
:040000006400000098
:00000001FF
Thank you for your explanation, it help me a lot!
TopJohn Samperi
TopI figure it out and finally- all works!
Thank you all. This is one fantastic forum! :D
TopAgain, I have a problem. I want to put 2 Arrays in EEPROM, and after to read them. I am certain that data are correct written into EEPRom (the .eep seys so because I defined Arrey[13] and in .eep found 4 lines with smth like arrey- the number I only used), but when I want to read them, there is a problem.
Thanks, again.
TopWhy read the whole array into RAM? Why not pick up the element you need one at a time? Anyway if you really want to read the whole array you do not want
TopOk! I'll try. Thank you for quick answer.
TopI updated the tutorial PDF contents on my site the other day to reflect the API changes made to the EEPROM library over the last few years. Download the PDF from here for the latest version:
http://fourwalledcubicle.com/AVR...
- Dean :twisted:
TopI am sorry to bother you again, but it seems that I can't put an array in EEPROM, I've read Dean's tutorial and I think I understood how it works, but it won't to read/write in EEPROM. Is there something else I can do that not include program, some adjustments in maybe AVR Studio 4 or ISP communication?
Thank you. :oops:
TopYou should produce a minimal but complete, clean building and runnable program that demonstrates the problems you describe. Ideally we're talking about perhaps 20 lines of code. Post that program here and we can help.
TopYes, I checked that box. Here is code:
TopPages
