Error compiling USB CDC example from AVR272 (AT90USB162)
3 posts / 0 new
I'm using Atmel Studio 5 (5.1.208) to build the CDC
example from AVR272 for a AT90USB162.
I get the following error:
expected '=', ',', ';', 'asm' or '__attribute__' before 'S_usb_device_descriptor'
for the line in usb_descriptors.c
code S_usb_device_descriptor usb_dev_desc =
with cursor on word 'code' the window shows:
typedef uint64_t prog_uint64_t PROGMEM
in file compiler.h under GCC Compiler (#ifdef AVRGCC)
#define code PROGMEM
when cursor is on word 'PROGMEM' window shows:
from file pgmspace.h (for not DOXYGEN and not mint8)
typedef uint64_t prog_uint64_t PROGMEM;
Not sure what is causing this. Since the source code
is from AVR272, I'm guessing I'm missing a #define
or other compiler switch.
Any help or ideas will be appreciated.
99 times out of 100 that says "I do not know the type being used in this line". Usually because the .h file where it is #define'd or typedef has not been parsed yet. Chances are you missed a required #include. Possibly in this case?
Thanks for your response.
The #includes are there, but the #define code ...
isn't necessarily being implemented. Not sure why.
I'm new to Studio 5 and not sure I have it set up
properly. Imported the files from AVR272 as Studio 4
project and not sure that worked properly ... I had
to add other files into the project that weren't
copied by the import.
I'm going to create a new project and try it again.
If anyone has had any experience working with the
files in AVR272 (USB CDC) I'd appreciate hearing
about your experience.
