AVR Dragon and AVR Studio 5.0.1223
12 posts / 0 new
So I've been gone most of the summer and I had to pack up some stuff while I was away. Now that I've returned had a serious problem and had to reload my machine with everything, OS included. So I got AVR Studio 5.0 out, updated to the new version did some work and worked fine, but wasn't using AVRDragon just Simulator. So today I want to get serious and hooked up the Dragon AVR Studio prompted to upgrade before I could continue so I did then tried to program a ATMega328p board that I've been using for quite a while, even used another board and am getting a "Failed to get interface clock value" error, in error popup window the details state "Failed to set interface [ISP]" and in the Studio output window it says
17:15:06.630: [ERROR] TCF command: Tool:setProperties failed: Code:1 ,Service:Tool ,Message from peer:Null pointer
17:15:06.654: [ERROR] Failed to set interface [ISP]
# Null pointer
17:17:39.769: [ERROR] TCF command: Tool:setProperties failed: Code:1 ,Service:Tool ,Message from peer:Null pointer
17:17:39.769: [ERROR] Failed to set interface [ISP]
# Null pointer
17:18:08.050: [ERROR] TCF command: Tool:setProperties failed: Code:1 ,Service:Tool ,Message from peer:Null pointer
17:18:08.050: [ERROR] Failed to set interface [ISP]
# Null pointer
17:18:11.590: [ERROR] TCF command: Tool:setProperties failed: Code:1 ,Service:Tool ,Message from peer:Null pointer
# Null pointer
# Error occurred in jtagice mkII event and response thread: Read from USB device endpoint 130 failed: HC status: PID stall (0xc0000004).
# Failed to execute command with ID 0x00.
# Attempted write to detached USB device.
17:29:47.497: [ERROR] TCF command: Tool:setProperties failed: Code:1 ,Service:Tool ,Message from peer:Null pointer
17:29:47.499: [ERROR] Failed to set interface [ISP]
# Null pointer
17:31:25.750: [ERROR] Skipping launch. User did not choose a debug tool.
# Null pointer
17:31:32.852: [ERROR] TCF command: Tool:setProperties failed: Code:1 ,Service:Tool ,Message from peer:Null pointer
17:39:15.547: [ERROR] TCF command: Tool:setProperties failed: Code:1 ,Service:Tool ,Message from peer:Null pointer
17:39:15.547: [ERROR] Failed to set interface [ISP]
# Null pointer
What the hell happened it was working slow but flawlessly when I left. Guess I was bragging on it to much. ???
Signed,
Bewildered
Happy Trails,
Mike
JaxCoder.com
Downloaded the latest version 5.1 of the IDE and with a little finagling and a lot of swearing I got it to work.
It's not obvious that's for sure?
Happy Trails,
Mike
JaxCoder.com
What was the issue?
- Dean :twisted:
I assume this was supposed to go on the end of https://www.avrfreaks.net/index.p... but OP used [New Topic] rather than [New Reply]
Topics merged.
- Dean :twisted:
Dean,
I had multiple problems;
1) Chip I was using was bricked, will have to reset.
2) Drivers flakey because I'm running Windows 7 and am currently working to get drivers reinstalled after putting windows in Test Mode.
3) My stupidity :)
I have one more really stupid question. I can now debug in AVR Studio 5.1 but can't program with the Dragon or UsbTiny, which I could do before so I'm thinking that the debugger has the chip locked.
Is there something you have to do after debug session to restore the fuse so I can program normally?
Mike
Happy Trails,
Mike
JaxCoder.com
The debugger has an option (not sure where it's now hidden in AS5) to say "disable debugWire" but it's only available while you are actually debugging (or at least this was the case in AS4).
clawson,
Yeah I remember that option in AS4 that's what made me think that that might be my problem but haven't found that yet in AS5.1.
Mike
Happy Trails,
Mike
JaxCoder.com
Which is amongst the many reasons why I'd still choose AS4.
If it ain't broke, don't fix it!
clawson,
Agreed but people were probably cussing AS4 till it got stable, which I would imagine took a while.
Happy Trails,
Mike
JaxCoder.com
The option is in Debug->Disable Debugwire and Close.
- Dean :twisted:
Dean,
Good god if it was a snake it would have bit me. :)
Mike
Happy Trails,
Mike
JaxCoder.com
