I just want to verify possibilities for using a 32 bit TC (two cascaded 16 bits TC) with output capture. And I am using PORTE on my ATxmega256A3 for this. If I use OCxA is my output compare pin the PE0 or PE4?
I do not find example on this setup.
I only see example of setup of a 32 bit input capture and in this case the input capture pin is PE0.
I am just trying to figure it out since I am about to design my schematic.
