Eeprom reads 255 for an address it doesnt have.
5 posts / 0 new
The atmega328p has 1024 bytes of eeprom. When I try to read an invalid address like 1900, it is sending a value '255'. Why is this happening? Please tell me why all the bytes of eeprom has a default value of '255'. Also the first byte already had a value of '105'. Does that mean something? I am using an arduino Uno.
Sometimes an invalid address is 'don't care' and sometimes it may cause an error / exception.
AVRs are fairly simple. They tend to just ignore the unused bits. So reading 1025 would just access 1 on a 1024 byte memory.
If your address #0 contains 105, see if address #1024 reads the same.
An unused memory is all ones e.g. 0b11111111 or 255.
Just out of interest what value were you expecting? It clearly has to be some value from 0x00 to 0xFF or do you know of some special state for 8 bits that is none of the above??
Look on the data sheet:
The unused address bits of EEARH are read only and always 0.
So writing these bits has no effect.
You access always a valid EEPROM byte.
Peter
I got it.. thanks for replying.
