My system: F_clock 8000000, atmega48
When I run USART on 9600 bps it works ok, with no errors, all characters are received correct on hyper terminal. The same is with 19200 bps. But I need higher speed..
I am working with HT, so when I'm setting to any higher baud rate available in the list, I am getting errors, characters are received not correct.
So, what you could suggest me, to get higher speed?
Use another terminal software? Or maybe there are some settings, that I need to set?
Any help would be appreciated! Thanks!
