My simple blinky code not working.
11 posts / 0 new
I wrote a simple blinky program but not working. The led stays OFF all the time. I use arduino Uno hardware with atmega328p mcu running at 16 mhz.
Edit: It blinks now. But there is huge lag in timer. I can measure around 6 seconds of lag in just 5 minutes. Here is the updated code.
 #include "Arduino.h"
#include
#include
void toggle_led(void);
unsigned long volatile millis_count = 0;
volatile char state = 1;
unsigned long volatile current_count = 0;
unsigned int volatile count = 0;
ISR(TIMER0_COMPA_vect) {        //Timer interrupt ISR
    millis_count++;
    if (millis_count - current_count == 1000) {
        current_count = millis_count;
        toggle_led();
        Serial.println(count++);  //prints the count
int main(void) {
    init();
    //Timer settings for interrupt at every millisecond
    TCCR0B = 0b11;  //prescaler set to clk/64
    OCR0A = 249;    //Compare match A register to 249
    TIMSK0 |= 0b10; //generate interrupt on Output Compare Match
    sei();
    Serial.begin(9600);
    DDRB |= 1<<5;
    for (;;) {
void toggle_led(void) {
    PORTB ^= (1<<5);
OOps I found the mistake..
(_count - current_count) should be equal to 1000 not 0.
silly mistakes.. >_<
How many iterations of the timer interrupt do you think need to occur before this condition will be met?
if (_count - current_count == 0)
count will have to increment through it's full range and back to 0 before this can happen, which would be over 4 billion. What's the timer interval set to? Note that commenting your code would be a big help here. No running to the datasheet to check every little thing.
Why all the extra variables? Can't a simple test like this work for you?
   _count++;
   if (_count > somenumber) {
      _count = 0;
      toggle_led();
Thanks for the suggestions. I tried to implement a lot of other function as a part of learning. Thats why there is so many unused variables.
Now it blinks. But there is lag error in counting. There is around 6 seconds lag in 5 minute. See the original post for the updated code. I have included a little documentation.
Think about it. You are getting an IRQ on TIM0_COMPA. The TCNT0 continues to count 249, 250, ..., 255, 0, ...
Hint. Look up CTC mode.
Why are you maintaining so many 'counts' ?
Don't call routines that require a considerable amount of time to execute from within an ISR.
Hint, your interrupts are disabled while you are in the ISR...
cheers,
george.
So if I put Serial.print() inside the 'for' loop in the main() instead in the ISR, does that will solve the lag?
OMG... I didnt think about that.. my bad :shock:
David, that totally worked. I added "TCCR0A = 0b10;" in the main(). And now its working fine. thanks a lot.
